Go Back   Plumbing Forum > General Plumbing Discussion > Plumbing Tools and Equipment
Old 07-28-2010, 08:52 PM   #1
Default PEX Crimpers
Hi Guys,
I'm new to the site/forum but not to the plumbing industry. My father and uncle have owned and operated a small manufacturing company in Pipersville, Pennsylvania (since 1973) that has since become the family business. We primarily manufacturer hand tools for the electrical industry, but recently have started manufacturing PEX Crimping Tools for professional plumbers and other DIY types.
Proudly manufactured in the USA, our Compact PEX Tool with Interchangeable Dies (patent pending) makes pex crimps even when placed literally against the wall. Utilizing our four link mechanism, this tool is the ideal solution for your crimping needs. Unlike other products, the unique interchangeable dies of this crimper allow the operator to quickly and easily change pex size with no additional tooling. As always, our many PEX tools are designed with overhead applications in mind. This line of tooling makes short work of any crimp that requires two hands to position the tool on the fitting.
My main point is this, check out our site at http://jennytools.com/ today!
Thanks,
Steve
JennyTools is offline   Reply With Quote
Old 10-14-2010, 07:25 PM   #2
HI
What vendors rings will these tools work with?
Thanks
Rich
clydewater is offline   Reply With Quote
Old 12-16-2010, 03:09 PM   #3
Good to see American manufactured tools.
plumbernyc is offline   Reply With Quote
Old 12-17-2010, 05:03 PM   #4
I still think this "one post" member is advertising.
Old 12-17-2010, 09:31 PM   #5
Plumbing Sales
SlowDrip's Avatar
ReeeeaaaAAAlllly?
Old 05-15-2011, 12:42 AM   #6
Another-Plumber's Avatar
i dont like the inter changeable dies, i would rather have 2-3 different tools than that trash, besides, when running pipe, you are most likely using only one size or the other, 1/2 or 3/4 so on, as your partner can be using the other tool, up above in the attic... so the small dies for me is a bad idea..
Old 07-25-2011, 03:15 PM   #7
What someone needs to make is a crimping tool with a ratchet, similar to a PVC cutter. Then you wouldn't need the long handles and they would work in tight spaces.
Old 07-25-2011, 03:42 PM   #8
Sounds like a great idea John!
havasu is online now   Reply With Quote
Old 07-25-2011, 03:57 PM   #9
Lets build one and we can sit back and collect royalties like the plumber that came up with the Fluid Master. Oh buy the way I saving this post in case someone comes out with one.
Old 07-25-2011, 08:17 PM   #10
Will's Avatar
I don't like the changing heads. I'd rather spend more and get one tool for each size, because it will last more in the long run. If my Mil 3 crimpers ever where out I might give yours a shot, but don't hold your breath. My Mil 3 crimpers will probably outlast me.
Will Rogers Plumbing
Moore, Oklahoma
(405) 323-2852
"We Unclog Drains That Others Can't"
www.willrogersplumbing.com
http://willrogersplumbing.com/?page_id=8
"Oklahoma's Favorite Plumbers!"
Will is offline   Reply With Quote
PEX, crimpers
