Plumbing Forum - Professional & DIY Plumbing Forum > Reviews > Plumbing Tools > Hand Tools > BullDog Drain Tool, Inc. - The "NEW" BullDog No-Caulk Drain Wrench
Old 02-14-2011, 11:27 PM   #1
The BULLDOG shower drain tool is by far the most innovative tool for the plumbing contractor or building professional involved in bathroom remodeling. It quickly and easily tightens both slip-on (no-caulk) shower drains, as well as the standard thread-on shower drain.
The BULLDOG is uniquely designed to slide between the inner portion of the lower, and upper, drain body and the ABS pipe to tighten the brass ring nut ensuring adequate compression of the rubber grommet. EVEN if the pipe is high or crooked.
Made of 1/2” solid steel with a rubber coated handle for comfort and a rust resistant coating.
srichter185 is offline
Tapping into 3" drain pipe? Bogucki General Plumbing Help 18 07-02-2012 05:29 PM
Tub shower with 1 1/2" drain to p trap question yzman720 General Plumbing Help 2 05-10-2011 01:54 PM
Adjustable "Metric" and "SAE" wrenches? havasu Plumbing Tools and Equipment 3 04-12-2011 06:58 PM
Adding drain line to 4" cast Cardinal General Plumbing Help 1 09-30-2010 12:44 AM
