Go Back   Plumbing Forum > Reviews > Plumbing Tools > Sensors and Electronics
Zircon - Zircon Electronic Metal and Rebar Locator Reviews, Ratings, Specs & Prices
Previous Product Sensors and Electronics Next Product
MSRP: $153.95
Manufacturer: Zircon
Company Website: http://www.professionalequipment.com/zircon-electronic-metal-rebar-locator-mt-6/rebar-locators/
Features & Applications:
With the ZIRCON Electronic Metal Locator you can graphically pinpoint the exact location and the type of a material. Find rebar, metal pipe, conduit, metal studs, junction boxes, and metal framing before you begin drilling. No more needless holes, costly broken drill bits and saw blades. The large, graphic LCD displays proximity, type of metal and depth of metal.
Differentiate between materials based on their magnetic properties-to a depth rounded up to the nearest 1/2 inch. Find steel rebar and copper pipe up to 6 inches within solid concrete.
Features:
Locates metal up to 6 inches deep
Finds all types of metal
Identifies magnetic vs. nonmagnetic
Indicates depth of metal found
Large LCD screen
Tough for jobsite use
Applications:
Find rebar, metal pipes, conduit, and plumbing before:
Drilling into slabs for anchor bolts
Coring through floors for wire bundles
Cutting openings in concrete walls
Drilling to add rebar to slab joints
Estimating a demolition job
Find nails in used lumber before sawing,
planing or sanding
Spec Summary:
Dimensions:8.87 L x 3.84 W x 2.23 in. D
(251 x 109 x 63 mm)
Weight:10.1 oz. (286 g) without battery
Battery type:9-V alkaline (not included)
Position accuracy:Center of #4 (1/2 in.) rebar or 1/2 in. (13 mm) copper pipe at a minimum
grid spacing of 6 in. (152 mm) typically within 1/2 in. (13 mm)
Depth:Up to 6 in. +/- 1 in. (152 mm +/- 25 mm)
Operating temperature:20 to 120°F (-7 to 49°C)
Storage temperature:-20 to 150°F (-29 to 66°C)
Humidity:80% RH (noncondensing)
Water resistance:Splash and water resistant, not waterproof
plumbing, zircon
