Plumbing Forum - Professional & DIY Plumbing Forum > Reviews > Plumbing Tools > Sensors and Electronics > Schonstedt Instruments - Pipe and Cable Magnetic Locator
Old 01-12-2010, 03:50 PM   #1
Keith's Avatar
Liked 3 Times on 3 Posts
Default Schonstedt Instruments - Pipe and Cable Magnetic Locator
Features & Applications:
Reduce costly and potentially dangerous mistakes by locating materials below a specified area. This highly productive magnetic locator is the most cost effective, all-purpose locating system on the market.
Magnetic Locator Mode, Only the receiver is required when operating in the magnetic locator mode. Just set the Mode switch to MAG, the Gain control to mid-range, and you're ready to use the magnetic locator to locate underground ferrous pipes, water meters, water valves, and property markers - or anything that has a magnetic field including the 50/60Hz electro-magnetic field generated by energized power lines
Transmitter Inductive Mode Induction is achieved by placing the transmitter over the target cable/pipe or by using the optional Inductive Signal Clamp. The trace signal generates an alternating magnetic field around the cable, which induces a signal into the receiver's cable sensor. A sharp null in the audio signal between the two peaks occurs when the receiver's tip is directly over the cable.
Transmitter Conductive Mode If an exposed section of a target gas or water pipe is accessible, conductive coupling is the most reliable method for applying the trace signal. Providing a good electrical contact between the clip and the conductive portion of the target line by removing rust or paint before attaching the clip is very important.
Features:
Two active frequencies for pipe, cable locator and line tracing
Power line detection warning
Inductive and conductive signal coupling
Extra Heavy Duty Clips and Cable
Five discrete sensitivity settings
Audio Tone
Water-resistant housing permits use in the rain
Patented HeliFlux® Sensors
Applications:
Underground Cable Locator
Surveyors' marker stakes
Valve boxes
cast iron pipe joints
manhole covers
Spec Summary:
Receiver
Operating Voltage:9V (2 alkaline or 2 lithium batteries)
Battery Life:60hrs, alkaline (on & off usage @ 70ºF)
120 hrs, lithium (on & off usage @ 70ºF)
Weight:2.64 lb. (1.20 kg.)
Operating Temp:-13 to 140oF (-25 to 60oC)
Overall Length:42.3 in. (107.4 cm.)
Waterproof Length:34.5 in. (87.6 cm.)
Transmitter
Operating Voltage:12 V (8 alkaline C-Cell batteries)
Battery Life:60 hours (on & off usage @ 70ºF)
RF Output:82.5 kHz modulated at 382 Hz, pulsed at 4.4 Hz
571 Hz Pulsed at 4.4 Hz
Audio Indicator:2.58 kHz pulsed at 4.4 Hz
Weight:Approx. 5.5 lb. (2.5 kg.)
Operating Temp:-13 to 140ºF (-25 to 60ºC)
Register Now!
Keith is offline
magnetic, pipelocater, plumbing
