Go Back   Plumbing Forum > Reviews > Plumbing Tools > Sensors and Electronics
Greenlee Textron - Tempo Tracker II Pipe & Wire Locator Reviews, Ratings, Specs & Prices
Search Reviews
Sensors and Electronics Next Product
MSRP: $853.95
Manufacturer: Greenlee Textron
Company Website: http://www.professionalequipment.com/greenlee-tracker-ii-pipe-wire-locator/wire-tracer/
Features & Applications:
Trace the path and determine the depth of wires and metallic pipes without having to deactivate the system. The inductive signal application of the Tracker allows you to use it on active or unenergized systems. Its high frequency transmitter provides a range up to 4,000 feet and depths up to 7 feet, employing three methods of detection: direct, inductive coupler and inductive antenna.
Use on active lines or where line isolation is not possible by clamping the inductive coupler directly around wire. The antenna allows the transmitter to be placed on the ground over the wire path to radiate a signal down to the conductor. Accurate identification is made simple with the 32” lightweight receiver, which provides both audible and visual indications; and has fully adjustable sensitivity.
Features:
Features 240 VAC & 500 VDC voltage protection & auto shut-off
Includes transmitter, receiver, inductive coupler & antenna, (2) 8 ft. leads with heavy-duty alligator clips, and a durable hard case
Requires (1) 9V and 8 AA batteries
plumbing, tempo, tracker
