Go Back   Plumbing Forum > Reviews > Plumbing Tools > Sensors and Electronics
Amprobe - Amprobe® Ultrasonic Leak Detector Kit Reviews, Ratings, Specs & Prices
Search Reviews
Previous Product Sensors and Electronics Next Product
MSRP: $368.95
Manufacturer: Amprobe
Company Website: http://www.professionalequipment.com/amprobe-ultrasonic-leak-detector-kit-tmuld-300/water-leak-detectors/
Features & Applications:
The Ultrasonic Leak Detector Kit contains all the accessories necessary to locate ultrasonic noise generated leaks.
ULD-300
The ULD-300 Ultrasonic Leak Detector is a compact, high quality and affordably priced ultrasonic leak detector that is a solution for many leak detector problems. The ULD-300 "hears" the ultrasonic noise created by any gas moving through a small orifice.
UT-300
In areas where leaking gases are not sufficently pressurized, there is no ultrasonic sound for detection. The area can be "pressurized" with the ultrasonic sound waves created by the UT-300 Ultrasonic Transmitter.
Features:
Detects any pressurized gas leak, regardless of type: CFC's, HFC's, Nitrogen, etc.
Unaffected by contaminants.
Unaffected by windy, roof-top conditions.
Detects the ultrasonic noise caused by arcing electrical switchgear.
ULD-300 Leak Detector
UT- 300 Transmitter
TE-2 Tubular Extension with adapter
HP-1 Headphones
PB-1 Parabola and the carrying case (ULD-CC).
Applications:
Useful in finding the ends of buried PVC pipes
Tests the “air-tightness” of weather seals, tanks, ovens, refrigerators, etc.
Locating leaks in duct work
The UT-300 transmits an ultrasonic signal for non pressurized applications
Pre-pressure testing of vessels
Spec Summary: ULD-300
Battery Check:
Green LED - Good
Red - Replace
Frequency Response:5KHz to 45Khz+ 6dB
LED:High Intensity for Outdoors
Power:9V Alkaline Battery
Consumption:22mA at 9V DC Visibility
Battery Life:33 hours
Case:High Impact ABS
Performance:Meets the A.S.T.M Standard
Weight: 5.6 oz. (160g) with Battery
Dimensions: Height: 2-1
amprobe
