Go Back   Plumbing Forum > Reviews > Plumbing Tools > Plumbing Test Kits
AccuTrak - AccuTrak Ultrasonic Leak Inspection System Reviews, Ratings, Specs & Prices
Plumbing Test Kits
MSRP: $1,029.00
Manufacturer: AccuTrak
Company Website: http://www.professionalequipment.com/accutrak-ultrasonic-leak-inspection-system-vpe-1000/water-leak-detectors/
Features & Applications:
By detecting the ultrasonic sound created by turbulence and friction in industrial equipment, these extraordinary instruments pinpoint compressed air leaks, vacuum leaks, refrigerant leaks, worn bearings, and internal leaks through valves and steam traps.
Features:
Advanced, digitally controlled unit
Dedicated touchprobe sensor for optimum sensitivity and sound quality
Two LED displays with peak hold
Separate volume and sensitivity settings
Wide dynamic range increases effectiveness in loud areas
Detector
Touchprobe & waveguide attachments
Headset
Battery
Owners manual
Instructional CD
A hard shell padded case
Applications:
Steam Trap Testing
Leak Detection
Detect Bearing Wear
Valve Testing
Spec Summary
Power:9V
Battery Life:8hrs. continuous
Displays: 10 element LED bargraph,and 4 element alphanumeric
Frequency Response:30-42 kHz Airborne, 18-22 kHz Probe (center)
Audio Output: 0 to 4 kHz
Sensitivity:-80dB/volt/microbar
accutrak, kit
