Wohler - Wohler VIS 330 Visual Inspection Camera System Reviews, Ratings, Specs & Prices
Search Reviews
MSRP: $4,899.00
Manufacturer: Wohler
Company Website: http://www.professionalequipment.com/wohler-vis-330-visual-inspection-camera-system-3683/pipeline-cameras/
Features & Applications:
This advanced camera system sheds light in the dark. The articulating eye of the full color camera head lets you take a close look at pipes, air ducts, chimneys, vents, cracks, welding seams, gaskets and manholes. The super bright wide screen TFT monitor provides brilliant picture quality. The waterproof 1 1/2" (40 mm) camera always fits. With its 180° pan- and 360° tilt-able camera head, it gives you an inside view into drainage pipes, air ducts and intermediate ceilings. The innovative design provides super bright lighting and simple operation, all in one heavy duty carrying case. A crystal clear picture appears on the wide screen TFT monitor so you identify problems before they occur. The Wohler VIS 3xx Advanced Camera System comes standard with a built in RCA video output for documentation on a VCR or other elec-tronic devices. The state-of-the-art NiMH battery packs each provide 1.5 hours continious operation. The power supply offers simoultaneous operation and battery recharging.
Features:
Battery Indicator: Shows the charging condition of the battery
High Power Batteries: 2 NiMH rechargeable batteries (12 V) each provide 1.5 hours of continious operation. The main battery is charged right in the heavy-duty carrying case
Color Monitor: The high resolution wide screen 16:9 TFT monitor provides brilliant picture quality and is both tilt- and removable
Keypad: Extra-large keys for menu navigation and simple control of the camera head
Pan and tiltable camera head: Easy and accurate inspection by a pan and tilt camera head (180° and 360°)
Rugged Heavy Duty Carrying Case: Camera monitor and accessories are all boxed in a heavy duty carrying case, bringing all the rugged durability you have come to expect from Wohler products.
All-encompassing: 360° pan- and 180° tiltable camera eye
Small dimensions: The camera head measures 1 1/2" (40 mm) diameter and 2 1/3" (60 mm) in length.
Waterproof: fully encapsulated waterproof camera head with exchangeable dome
Flexible: 90°-bends are easily negotiable for the camera.
Super bright lighting: The LED lighting of the camera head gives crystal clear pictures, even in dark environments.
Exact location: digital distance measurement with a resolution of 0.05 ft
Versatile applications: The Wohler VIS 3xx Advanced Camera System is the essential tool to determine problems.
The articulated eye of the full color camera head lets you take a close look at:
Pipes
Air ducts
Chimneys
Vents
Cracks
Welding seams
Gaskets
Manholes
Specifications:
Monitor:
Size housing: 7" x 4.5" x 1.3"
TFT-Display: 7" / 16:9 format
Video-Out: FBAS
Current supply: 2 x 12 V batteries
or mains supply
Battery life time: appr. 1.5 hours per battery
Sensor type: 1/3" COLOR CCD
Sensitivity: 0.5 Lux
Lens system: f = 0.08", F = 2.4
Field of view: 120°
Light source: 12 white LEDs
Protection: waterproof according to IP 68
Size: 1.5" x 2.4"
Rod:
Length: 65 ft.
Diameter: 0.26"
Carrying Case:
Size: 20" x 17" x 7" (l x w x h)
Weight: 18 lbs
camera, plumbing, wohler
