Wohler - Wohler Video Inspection HVAC System
Wohler Video Inspection HVAC System brings together a unique blend of technology, portability, ease-of-use and affordability. It is light, yet rugged, and with internal rechargeable batteries, you get unmatched portability with a hand-held "go anywhere" attitude. Horizontal or vertical, elbows or bends, top-down or bottom-up, the VIS2000 has it covered.
The Standard VIS2000 monitor - Bright, high resolution TFT LCD screen, video-in and out sockets, removable, rechargeable 12V battery and handy, rear swivel cable connector.
Patented Pan & Tilt Camera has a true 360º x 180º rotation so you get a full view of your inspection.
Features:
Included in system:
Standard VIS2000 monitor w leather case
On screen distance measurement
P&T Camera with 360 x 180 action
Camera roller
Power supply
65' 7mm Video rod & reel
Stand
36" Gooseneck
Plastic case
XXL case
Applications:
Chimneys
Vents
Power plants
Quality control
Pest control
Ducts
Construction
Home inspection
Security & surveillance
Search & rescue...and much more
Spec Summary Standard Monitor:
Weight: 2.4 lb
Dimensions: 8.5L x 5.1H x 2.4"W
Screen Size: 5.6" diagonal
Resolution: 960 x 234 pixel TFT-LCD
Video-out: 1V analog S video/ composite
Batteries: 12V NiMH
Pan & Tilt Camera:
Weight: 8.5 oz.
Dimensions: Ø2", 3.9"L
Device: 1/4" CCD NTSC
Sensitivity: 0.4 lux color
Sensor resolution: 542 x 586 pixel
Focal length: 2.0 mm
FOV: 98° x 75°
Pan & Tilt: 360° x 180°
Lighting: 4 bulbs + 6 LED hi beam (color)
Register Now!
