Uemsi - ProCam DVR Standard, Color Mini Camera Inspection System w/ DVR Player / Recorder - U Reviews, Ratings, Specs & Prices
MSRP: $5,095.00
Manufacturer: Uemsi
Company Website: http://www.professionalequipment.com/procam-dvr-standard-color-mini-camera-inspection-system-w-dvr-player-recorder-uemsi-75-1900-200/pipeline-cameras/
Features & Applications:
The ProCam DVR is an extremely compact and lightweight mini camera system you can’t live without. Having the same high quality standards and durability you have come to expect from UEMSI, the ProCam DVR system is setting the new standard of the industry. It incorporates the latest technology, which includes a 10.4” color LCD monitor and a DVR player / recorder with a built-in 160 GB hard drive and SD card holder. This equipment is housed in a heavy-duty case, with a total weight of only 17 pounds. The ProCam DVR system not only operates on both 110 VAC and 12 VDC, but also has two rechargeable battery pack options availbale. The system is designed for inspecting sewer pipelines, HVAC ducts, chimneys and other enclosed cavities.
Standard with the ProCam DVR system is UEMSI’s proven multi-conductor video push cable. It is the strongest in the industry enabling the user to push long runs, yet fl exible to handle tight corners in small pipe. The cable also includes a water-blocking gel inside to prevent water infi ltration, if it were to become damaged. It is equipped with our interchangeable, 1.4” OD x 2” L, CM-1 color camera head.
Features:
DVR player / recorder with built-in 160 GB hard drive, which has 110 hours of recording time
Built-in USB port to transfer video and audio to user’s computer hard drive
Built-in SD card holder, allowing video and audio to transfer to SD card
Hand held microphone
Variable light intensity
Snap-on sun shield
Video and audio output RCA connections
Power control unit only weighs 17 lbs.
200’ of video push cable with water-blocking gel
Capable of inspecting a minimum of 2” straight pipe
Cable reel constructed of lightweight, heavy-duty steel tubing
Lightweight and durable aluminum camera housing
4”- 6” Brush skid
110 VAC or 12 VDC operation
Reel Assembly:
Durable steel construction
Maintenance-free slip ring
Rugged wheels for easy mobility
Fiberglass rod imbedded in video cable for rigidity
4" fl exible spring for easy bend ne go ti a tion
Reel dimensions: 34" H x 14" W x 30" L
Reel weight w/ 200' of cable: 49 lbs.
Hand brake prevents reel from turning during transport
CM-1 Color Camera Head:
Video output: 1.0 V p-p NTSC standard, 75 ohm
Imaging device: 2 lux solid state
2:1 interlace scanning
Scan frequency: 15.734 KHz; 59.9 Hz
300,000 pixels
460 lines (h) resolution
100º lens, 2.5 mm, f 1.8
Power: 12 VDC
O-Ring sealed aluminum housing
Equipped with 15 white LEDs
Variable light output
Lighthead housing: high strength, clear polycarbonate
Camera dimensions: 1.4" OD x 2" L
Camera weight: 3 oz.
Power Control Unit:
Rugged, lightweight, easy-to-carry briefcase-style vpower control unit case
Hinged lid with built-in storage compartment
Power indicator LED
Complete monitor and camera controls with variable light intensity
Snap-on sun shield
Video and audio output connections
Light head power supply: 0-12 VDC
Case dimensions: 5.375” H x 14.25” W x 16.375” L
Weight: 17 lbs.
camera, plumbing
