Ridge Tool Company - Ridgid® SeeSnake® MicroDrain™ Inspection System
Features & Applications:
This Ridgid SeeSnake MicroDrain inspection system has multiple monitor compatibility that allows you to use the microDrain reel with your SeeSnake monitor or the microExplorer digital inspection camera. It represents a huge leap forward in small diameter drain inspection technology paired with the durability you expect from RIDGID®. The microDrain will allow you to quickly inspect places previously unreachable – providing true accessibility, increased efficiency, and reduced job time. Features a hardened stainless steel camera head w/ saphire lens cover, a polypropylene coated w/ fiberglass inner core push rod, metal frame and a polyethelene drum
Comes with the new Ridgid® MicroExplorer™ Digital Inspection Camera which is a powerful, hand held, video inspection system that is portable enough to be carried anywhere. This completely digital platform allows you to perform and record detailed visual inspections of hard to reach areas. The MicroExplorer™ Digital Inspection Camera allows you to offer more services and provides you the tools you need to detect and diagnose the unreachable. This inspection camera accepts an SD card to save your images, it self rights your images for review and has the ability to output video via the supplied usb cable. It outputs images in .jpeg format and video in .avi format.
Features:
Small Diameter and Tight Turn Radius camera head gets you through many toilet traps and 1 1/4" lines.
Multiple Monitor Compatibility allows you to use the microDrain reel with your SeeSnake monitor or the microEXPLORER™ Digital Inspection Camera.
Lightweight and Compact unit allows you to easily stow and carry the camera in your truck and onto the job site providing solutions whenever and wherever you need them.
Durable and Reliable construction quality that you have come to expect from the RIDGID SeeSnake name.
Specifications:
Camera Head: 0.86" (22 mm)
Cable Length: 30' Cable (10 m)
Cable Diameter: 0.33" (8.3 mm)
Line Capacity: 1.25" – 3" (32 mm – 76 mm)
Weight: 8.6 lbs. (3.9 kg)
Length: 13.25" (33.7 cm)
Width: 6.6" (16.8 cm)
Height: 17.5" (44.5 cm)
Resolution: 510 x 496 NTSC
Includes: Monitor and Ball Guide
Power Source: Rechargeable Li-Ion Battery
Connector Type: 9-Pin Screw
Waterproof: Camera Up to 330 Ft
Monitor Size: 3 1/2"
Monitor System: LCD
Camera Type: Wide Angle Viewing w/Adjustable LED's
Register Now!
