Extech - Extech Video Borescope / Wireless Inspection Camera Reviews, Ratings, Specs & Prices
Search Reviews
MSRP: $299.99
Manufacturer: Extech
Company Website: http://www.professionalequipment.com/extech-video-borescope-wireless-inspection-camera-br200/pipeline-cameras/
Features & Applications:
This Extech video borescope / wireless inspection camera features a 3.5" color TFT LCD monitor. The memory card allows for capturing images (JPEG) or video (AVI) for viewing on your PC. Complete with 4 AA batteries, microSD memory card with SD adaptor, USB cable, extension tools (mirror, hook, magnet), video interconnect cable, AC adaptor (100-240V, 50/60Hz), magnetic base stand, and storage case. Detachable wireless 3.5" color TFT LCD display can be viewed from a remote location up to 32ft (10m) from the measurement point.
Features:
Memory card for capturing images (JPEG) or video (AVI) for viewing on your PC
39" (1m) flexible gooseneck with waterproof camera (17mm diameter) and 2 built-in bright LED lights for illuminating dark areas
Captured videos and images can be viewed on the wireless monitor or transferred to your PC via the microSD card or USB cable
NTSC or PAL operation with menus in 10 languages
Ideal applications: water restoration, HVAC and refrigeration, electrical inspection, automotive, pest control
Complete with 4 AA batteries, microSD memory card, SD adaptor, USB cable, extension tools, video cable, AC adaptor, magnetic base stand and storage case
Applications:
Home inspection: Inspect in walls for mold, insect infestation, electrical wire or water pipe location
HVAC: Inspect inside ducts, behind motors and compressors
Automotive: View inside or around engines and transmissions
Government: Safety and security inspections
Industrial: Inspect weld integrity, process equipment, gears, molding machines
Aerospace: Aircraft inspections for contamination, debris, cracks or other damage
Specifications:
Camera
Pixels: 712 x 486 (NTSC)/704 x 576 (PAL)
Transmission Frequency: 2.4GHz
Modulation Type: FM
Bandwidth: 18MHz
Transmission Range: 32ft (10m) unobstructed view
Viewing direction: Viewing Angle 50°
Viewing distance: 5.9"to 9.8” (15 to 25cm)
Shaft diameter: 0.66" (17mm)
Minimum bend radius: 2.36" (60mm)
Working length: 39" (1m)
Camera Dimensions: 7.3 x 5.7 x 1.6” (186 x 145 x 41mm)
Weight: 18.7oz (530g)
Monitor
LCD Screen Type: 3.5” TFT
Pixels: 320 x 240
Video Output Level: 0.9 to 1.3V@75O
Frame Rate: 10, 15, 20, 25, 30FPS
Video Resolution: 960 x 240 (avi format)
Image Resolution: 640x 480 (jpeg format)
Monitor Dimensions: 3.9 x 2.7 x 1" (100 x 70 x 25mm)
Operating/Charge Time: 1.5 hours/3 hours
Weight: 4.9oz (140g)
camera, extech
