Go Back   Plumbing Forum - Professional & DIY Plumbing Forum > Reviews > Plumbing Tools > Cameras
Aqua Communications - SnakeEye™ III Remote Video Inspection System Reviews, Ratings, Specs & Prices
MSRP: $3,400.00
Manufacturer: Aqua Communications
Company Website: http://www.professionalequipment.com/snakeeye-iii-remote-video-inspection-system-bk-03w/pipeline-cameras/
Features & Applications:
The SnakeEye™ III remote video inspection system is ideal for visual inspection of hard-to-reach areas with access greater than 1.1 in (27.9mm). It is a hand-held, electronic appliance that incorporates the latest in remote visual inspection (RVI) technology. It will provide years of reliable service when properly operated and maintained. SnakeEye™ is a low-cost hand held remote video inspection system. Lightweight, modular and portable, SnakeEye™ "lets your eyes travel where you can't." Combining a CCD camera and TFT-LCD display technology, SnakeEye™ delivers crystal-clear, full color video at a fraction of the price of current remote video inspection systems. SnakeEye™ is modular in design so that it can be easily configured to inspect ... behind walls, inside ceilings, in and around pipes and machinery, under vehicles and aircraft, inside engine compartments, behind computer equipment, underneath automobile dashboards … the possible uses are endless. SnakeEye™ is ideal for quick, non-destructive, qualitative inspections in hard-to-reach places.
SnakeEye™ achieves its versatility with an interchangeable camera head that can be attached to a rigid wand, a ring finger attachment or extendible cables. SnakeEye™ comes equipped with a full range of accessories and also has plug-in capabilities, one of which allows the user to connect to a standard VCR, a computer or a handy cam to record and playback images. SnakeEye™ is designed to function in harsh industrial and commercial environments and is constructed of high impact, heavy duty plastic that can withstand shock and vibration. SnakeEye™ resists water, dust, and dirt particles and can also be used where grease and non-solvent based chemicals are present. It has the ability to record snapshots that are stored on a removable SD (Secure Digital) card or, when connected to a VCR, as streaming video. It also includes an audio function. With the audio function, you can add stand-alone voice not during live video mode. Also, you can add audio comments to individual snapshots stored on SD card while you browse the images.
Hand Held Display Unit:
SnakeEye™'s lightweight, compact display unit (less than 2 lbs.) houses a high resolution (960 x 234) full color 5" TFT-LCD display and rechargeable battery pack. The display screen has a built-in protective, plastic cover and can be rotated to maintain proper image orientation for the viewer. Designed for easy one-handed operation, the display unit contains three color-coded push button controls: Power On/Off, Camera Head Light On, low, medium, high or Off for operating in low light conditions, and an image orientation control that rotates the image 180 with the touch of this control switch. Two ports at the base of the display unit allow for additional plug-in capabilities: Video In/Out connects to a standard VCR, a computer equipped with an analog to digital "frame grabber", or to some handy cams that have a video "in" port for image recording and playback; AC/DC adapter and 12 volt auto adapter allow for continuous non-battery power operation.
Removable Camera Head:
SnakeEye™ is equipped with a high speed CCD color camera with built-in 3 level (low, medium and high) LED illumination that delivers clear images in low light conditions, constant image clarity with variable object distance and minimum image distortion. The camera head contains four white LED's, which are controlled by the Camera Head Light button on the display unit. The water resistant camera head is 1.32" in diameter and is ruggedized for optimum performance in harsh environmental conditions. When used in combination with the rigid wand, the camera head can be vertically articulated up to 90°.
Interchangeable Camera Head Adapters:
SnakeEye™ incorporates a series of fully interchangeable camera head adapters to allow for multiple uses. A 4' Superflex Cable connects the display unit to the rigid wand and the ring adapter.
Ring Wand Adapter:
The SnakeEye™ Rigid Wand Adapter is 18" long and contains a SureGrip handle as well as a swivel feature that allows the user to vertically articulate the camera up to 90°. The rigid wand configuration is designed to insert the camera into hard to reach spaces such as overhead air ducts and behind walls.
Ring Adapter:
The SnakeEye™ Ring Adapter literally puts the camera on the user's finger. The ring adapter is designed to provide finger tip control of the camera in hard to see but reachable spaces such as underneath automobile dashboards and any place your hand can reach but your vision is obstructed.
Extension Cable Adapters:
SnakeEye™ extension cable adapters are comprised of heavy duty, plastic coated cable designed for use in harsh environments. These extension cables are available in multiple lengths and are suited for deep insertions such as chimney, pipe, and tank inspections.
Power System:
SnakeEye™ comes equipped with a rechargeable Nickel-Metal Hydride battery pack and charger. The battery pack provides up to 60 minutes of continuous operation. In addition to an On/Off control, SnakeEye™'s power management system contains a Low Battery Indicator that alerts the user when 75 seconds of the battery power is remaining, and an Auto Shut-Off feature when the battery voltage falls too low.
Features:
5 in (12.7cm) Color VGA LCD
Three level camera light control low/med-high-off
Still image recording
Voice note recording
IP68 Compliant (waterproof up to 10 feet in depth)
Total system weight- less than 3 lbs (1.4kg)
Applications:
Behind walls
Inside ceilings
Pipes
Machinery
Specifications:
Display Unit:
5 in (12.7 cm) color VGA TFT-LCD
640 x 480 color pixels
Adjustable hand strap
Three level camera light control low/med- high-off
Still Image Recording
Voice Note Recording
Three Screen Image Control: Normal - Mirror - 180 Degree Rotation
External power port
RCA port for Video I/O
Camera:
CCD camera
1.1 in (2.79 cm) diameter
1.92 in (4.8 cm) long
Sensitivity = 2 lux @ F3.5
CCD total pixels 771 x 492
Field of view 45 degrees
Depth of field 1.5 in (3.8 cm) to infinity
4 White light LEDs; 3 levels of brightness
Water proof to 30ft (10m)
Power System:
Battery
Up to 60 min continuous operation
2 x 6V NiMH rechargeable batteries
Battery charger
Continuous
AC/DC adapter
12 V auto adapter
Camera Adapters
Rigid Wand Adapter
18 in (45.7 cm) length
90 degree one way articulation
Sure-grip handle
Finger Adapter
General:
Total system weight- less than 3 lbs (1.4 kg)
Power requirements:
AC Nominal input: 100-240V
DC nominal input: 12V
System operating temperature:14 degrees F to 140 degrees F (-1O degrees C to 60 degrees C)
Video input/output: NTSC
Camera, video inspection
