Aqua Communications - SnakeEye II Remote Video Inspection System Reviews, Ratings, Specs & Prices
Previous Product Cameras
MSRP: $1,799.00
Manufacturer: Aqua Communications
Company Website: http://www.professionalequipment.com/snakeeye-ii-remote-video-inspection-system-snakeeye-ii-basic-kit/pipeline-cameras/
Features & Applications:
This versatile diagnostic tool can be invaluable in many instances-for industrial inspections of machinery and pipe; for building inspection and maintenance of plumbing and wiring behind walls; for search and rescue missions; and even for aviation and vehicle applications.
Cleverly designed for ease-of-use, this portable and lightweight system can be maneuvered and carried without interference to the task at hand. The hand-held, high resolution color display screen gets attached to a 4' flexible cable, connecting to a lightweight and rigid wand. The CCD camera (with LED lights) can either attach to the wand, equipped with 90 degree articulation, or connect to the ring adapter, which is then guided by hand. As each situation is different, you can easily adjust the backlight brightness or turn the camera lights on/off.
Features:
Viewer features color-coded, push-button controls for on/off, high/low brightness, and camera lights on/off
SnakeEye kit includes 5" display viewer with hand strap, 4' cable, wand, camera head, ring adapter, rechargeable battery pack with AC & 12V adapters, hard carrying case
90 day warranty on unit if defective
Applications:
Behind walls
Inside ceilings
Pipes
Machinery
Spec Summary: Display Unit
5 in (12.7 cm) color TFT-LCD
320 x 234 color pixels
Camera
1.2 in (3.0 cm) diameter
Sensitivity 10 lux
Resolution 512 x 492
Field of view 46 degrees
Water proof to 100 ft (30m)
Power System
Up to 90 min continuous operation
2 x 6 V NiMH rechargeable batteries
Camera Adapters
18 in (45.7 cm) length
90 degree one way articulation
4 ft (1.2 m) flexible cable
General
Total system weight- less than 2.5 lbs (1.1 kg)
Power requirements: AC Nominal input: 100-240 V, DC nominal input: 12V
System operating temperature- 32 degrees F to 122 degrees F (O degrees C to 50 degrees C)
Video input/output- NTSC
camera, plumbing
