Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Drain and Sewer Cleaning > Water coming up in kitchen sinks
Old 02-08-2014, 12:33 AM   #1
edee_em
Default Water coming up in kitchen sinks
Any thoughts on what makes water come up out of kitchen sinks when they seem to be draining properly? The only glitch we could see is when both sinks are full of water and you try to empty both at the same time. It seems to get overwhelmed and stops draining. I plunged the kitchen sinks extensively to the point that I could smell sewer gases (I'm thinking I cleared the trap of water). Ran some water and the smell went away but the sinks behaved in the same way. The homeowner told me that she noticed the sinks backing up while someone was showering. I believe the drains for the washroom and the kitchen sinks drain to the same pipe. Thoughts? Is this simply a clog or is there some fundamental problem with the piping? Another point of information: This only just began, it's not an ongoing issue and it did happen before. She had RotoRooter in and they snaked the line with good results. She is concerned that she doesn't want to have the expense of snaking lines every year or two. One more, the p-trap is in the finished basement ceiling and it is a fixed type.
Thanks!!
edee_em is offline
Old 02-08-2014, 01:38 AM   #2
Liked 391 Times on 328 Posts
Likes Given: 556
It sounds as though there is a partial blockage in the drain serving the kitchen sinks, and possibly, the bathroom. If she doesn't want to have the lines snaked regularly, I would recommend that she hires someone to snake the drain lines, and then camera inspect them to make sure that the pipes are completely opened. This will cost more than just a basic snake job, but will verify the condition of the drain piping.
2
People Like This
Old 02-08-2014, 03:16 PM   #3
edee_em
Thanks phishfood. I appreciate your response. I think I will recommend the camera and snaking. This is a new house for her and I think someone looking at the plumbing from the inside would be a great idea. While I have you, what are your thoughts on "hydro" snaking? We have an outfit up here that does high pressure water snaking of pipes. The theory is that it cleans the whole inside of the pipe better than a regular snake. Thoughts?
edee_em is offline
hot water in all tubs but not sinks dkw1977 General Plumbing Help 1 08-14-2013 10:19 PM
Water coming out of water heater power vent stevemachine Water Heaters and Softeners 6 12-23-2012 03:36 PM
Hot water from bathroom sinks. Chris General Plumbing Help 7 12-28-2010 03:15 PM
Only Air Coming out of Hot Water deceived Water Heaters and Softeners 14 12-20-2010 01:45 AM
What kind of brand kitchen sinks do people like? HomeIndoor Plumbing Products 15 12-17-2010 02:22 AM
