Washing machines are really hard on the drain lines. The amount of lint they put in the lines is the main reason. When you try to snake them out, the lint allows the snake to go through and then reseal when it is withdrawn. Since your problem occurs when draining the sink, I think the lint may also be clogging the sink pipe also. You may want to try an enzyme drain cleaner such as Draincare. It takes overnight to work, but enzyme drain cleaners cling to, and eat, organic clogs.
