utility sink
I want to add a utility sink on the right side of my washer. Inbetween the studs which are 16" o.c.there is a main drain and vent that goes from the slab up to the ceiling, and the stand pipe on the right that the washer drain hose sits in that is 34"off the floor and a p-trap connects the two pipes. My question is, can I put a separate p-trap from the new sink and connect it directly to the stand pipe or can I connect it via the p-trap directly to the main drain that goes from the floor to the vent up the ceiling? Any advice would be appreciated. Thanks, Dave in Marysville, WA
