Old 08-15-2010, 05:02 AM   #1
Otahyoni's Avatar
Default Slow toilet/sink/tub drain
My mom-in-law's bathroom is having drain troubles. After running the tub for a few minutes the drain line seems to fill up and then the water in the sink/tub will rise. The toilet also gurgles, as if air is being pushed out of it.
As a test, i flushed the toilet 3 times. The first two drained normally. The third flush drained part way then stopped draining. Listening to the pipe i could hear the water draining slowly.
I told her to call a plumber on monday to snake the line.
I removed the cleanout plug and was able to push a wire snake from there to the cast iron elbow, but couldn't get past the elbow.
I'll add some pictures of the drain asap...
Help please? Ideas on what could be wrong?
Thank you guys!
~The Amish Wolfman
I am known by many names:
Old 08-15-2010, 05:06 AM   #2
Sounds like an obstruction/clog in the main line. Are there trees in the yard?
Old 08-15-2010, 06:34 AM   #3
Otahyoni's Avatar
Not in the back yard. The only tree is at the front of the house. The sewer exits toward the alley...
~The Amish Wolfman
Old 08-20-2010, 01:27 AM   #4
Here's my tip..... I'm not a plumber but... did you try attacking the bathtub with your plumbers helper - the plunger? Same thing happened at my house and that fixed it. Loosened up whatever was in there. You want to put enough water in the bathtub or sink to cover the bottom of the plunger, block the overflow outlet with a rag or something, and plunger up and down five or six times. The pressure might clear a clog and open up the pipe. Lift it up and see if the water drains away. If it doesn't, try plunging again cause it might have just moved the blockage down the pipe where it got stuck again.
Might not work but worth a shot.
ouch202 is offline   Reply With Quote
Old 08-20-2010, 03:42 AM   #5
Otahyoni's Avatar
She called a plumber, and even though my wife talked to her, she can't tell me what was in the pipe...
I'll come back when i know more...
~The Amish Wolfman
Old 08-21-2010, 05:04 PM   #6
Otahyoni's Avatar
Turns out it was the neighbor's tree roots that got into the pipe.
~The Amish Wolfman
Old 09-02-2010, 11:33 PM   #7
Did you get a DNA sample so can you ID the culprit.
Roots mean a broken line. New technology can pinpoint the intrusion.
Have a pro with a line camera inspect it and pinpoint it so you can make a more informed decision on whether or not you want to dig it up and have it fixed.
They will grow back.
Old 09-03-2010, 02:48 AM   #8
Otahyoni's Avatar
I doubt she'll want to spend the money on it... I think he just cut the roots out of it... don't really know.
~The Amish Wolfman
