Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Drain and Sewer Cleaning > Slow Basement Drain
Old 01-15-2013, 04:07 PM   #1
Default Slow Basement Drain
What are my chances of unclogging a slow basement drain with a little Muriatic Acid ? I has seen plumbers use it before and they would just made sure they ran plenty of water down the drain after they were finished. Now bare in mind I'm talking about a home that was built in 1925 and there are about four different floor drains in the basement and they all drain fine except one we have been using for our washer drain and of course they are cast iron drains . The drain that is slow is only about 25 to 30ft long and runs into another line under the poured cement floor that runs fine. I have used snakes in all clean outs which I am so thankful for but this drain well I'm going to say all drains are static and getting any kind of snake in them is beyond me if I can take a picture of them I will and post here. Any comments would be taken with good advice and intentions.
I found this on the internet and mine are the same just a screen over them.
dbailey60 is offline
Old 01-15-2013, 05:38 PM   #2
Liked 60 Times on 53 Posts
Likes Given: 12
Well I wouldn't recommended any drain chemicals. Especially old piping in my opinion its suicide. It could turn ugly quick, from a hundred some dollar job to hire someone to auger it out to Hundreds or a thousand dollar job to replace some piping under concrete. It's your call but drain chemicals used properly don't always work effectively. I'd just get it augered/snaked and save the headache.
johnjh2o Likes This
Old 01-16-2013, 01:31 AM   #3
Liked 105 Times on 91 Posts
Likes Given: 239
On cast iron piping, I would strongly recommend against using any kind of acid, that is a good way of turning a clogged drain line into one needing replacement.
A skilled drain guy can usually get into and through most kinds of drains.
Old 01-16-2013, 02:35 PM   #4
I hear what is being said and I do agree it is just that I can not even get a small snake to go through this small opening at the bottom of the drain which take's a small curve to the left facing the drain . I would say the drain opening at the bottom is only about 2 inches in diameter and have or at least seems I have done everything I can to get a small snake 1/4" to go any where with out any success. I make it about six inches and that's it. It drains ok but not as fast as the other two in the basement.
If I remember right when we first bought the house in 2007 all the basement drains were clogged and I rented a commercial auger ran it down all clean outs and everything went as I had hoped meaning all drains flowed freely and I have just completed another session of drain cleaning with my small 1" hand held snake and on all cleanouts I can manage to use it on are clean as can be just as before when using the larger auger. I'm going to say that since this drain is being used as a washer drain it must be lint getting past my screen and it looks as though this drain is no longer than 20ft at the most. I am stuck on what to do next as I hate getting on my knees as I used to being an age problem and all the hard work I have done in the past as a matter of fact I was a residential construction crew boss at one time and built many stick homes at one time and would love to do it again but my body says no. Darn knee's!
So if any body has any more Idea's please through them at me I really do not want to go the plumber route but if I have to I have to.
Old 01-16-2013, 03:32 PM   #5
Likes Given: 12
The 1/4 cable your trying to use is it power or handheld? You may need a good powered snake to punch through it, maybe your getting stuck on an elbow? It's hard to say without physically being there. You may want to look into a drain enzyme and try that. It may make a difference. I would agree its lint more than likely. The scale on cast iron catches a lot of stuff and plus the soap scum causes the lint to bunch together in the drain, most enzymes will eat up the soap scum and therefore should alleviate your issue, especially if you use the enzymes regularly like monthly.
Old 01-16-2013, 09:58 PM   #6
Liked 66 Times on 56 Posts
Likes Given: 53
Do your floor drain have a clean-out on the inside wall of the drain, if so remove the clean-out cap/plug and pour water down the drain to see if it drains, if it drains then your problem is in the trap ,if not it's the drain line (and possible the trap). If the problem is in the trap I have had luck running a 1/4'' power cable with a wet/dry vac hose in drain(pushed down to the trap entrance) while running the cable.
Old 01-16-2013, 11:10 PM   #7
Liked 117 Times on 107 Posts
Likes Given: 69
If the line is 2" I wouldn't use a 1/4" cable. A cable that small in a line that size can turn on itself and become stuck in the line.
Old 01-17-2013, 02:57 AM   #8
Likes Given: 53
I agree John that the cable can come back, But we use 1/4'' cables on 2'' shower drains & floor drain traps all the time, but then again we're professional and know how to handle a drain machine. 3/8'' or little bigger would be a better choice.
Old 01-18-2013, 01:43 AM   #9
stevemachine , the 1/4 is just a handheld and there is an elbow at the bottom of the drain I can manage to get two fingers in it. It turns to the left when facing the drain from opposite side of opening facing the outside wall. If I had to make a wild guess the clog is way past the elbow. I have no clean out on that drain but have removed three others and had a blast ! Ha ! I will probably go ahead and rent me a power auger and run with that to see if I can get any where. I'll even jump up to a 3/8's to keep everyone happy . I don't think I mentioned it but I've only got about 10 to 12 ft. to reach before I run into the main drain ( 6 in ) that I just ran down with a 1 in power auger. Clean as a pin !
Old 01-18-2013, 03:15 AM   #10
Likes Given: 12
Yes definitely get a power auger, and you'll probably wind up with a drill type or something if you rent which typically. Only advantage to 1/4 is they usually can make it through a trap easily but I'd suggest for a homeowner (like John already said) 3/8. I'm sure that will do the trick for ya. Those hand augers usually can't punch through any decently solid blockage, unless its really soft maybe.
Drain In Bathroom Sink Drains Slow nhoj Toilets and Sinks 4 09-17-2012 07:55 AM
Basement Sink Slow Drain, Possible Sump Pump Issue? clourie Drain and Sewer Cleaning 5 05-24-2011 11:05 AM
New bathroom sinks drain slow Gus General Plumbing Help 21 02-01-2011 02:37 PM
Basement Floor Drain is slow GJinVA General Plumbing Help 3 12-31-2010 08:38 PM
Slow toilet/sink/tub drain Otahyoni Drain and Sewer Cleaning 7 09-03-2010 01:48 AM
