Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Drain and Sewer Cleaning > Shower and toilet
Old 01-31-2014, 02:51 PM   #1
RedRaider
Default Shower and toilet
Hello,
After about 5 minutes in the shower the toilet started gurgling and right after that the shower stopped draining. I then got out of the shower and tried to flush the toilet and it would not flush. The water in the toilet went down I a couple of minutes and I was then able to flush it normally. The shower also drained within a short time after getting out. Can you tell me what's up and how to fix this problem?
RedRaider is offline
Old 01-31-2014, 11:38 PM   #2
Liked 194 Times on 140 Posts
Likes Given: 112
You have a clog in the drain. You may have to remove the toilet to access the drain or possibly go through the shower drain with a cable snake (drain auger).
Not sure what your skills may be like to accomplish this or if you are comfortable with it.
Old 02-01-2014, 01:48 AM   #3
Sounds like a main line stoppage. If the toilet doesn't flush after using the shower the main line is plugged.
Caduceus Likes This
Old 02-01-2014, 01:32 PM   #4
RedRaider
Thanks, guys. I appreciate it!
blocked toilet and shower NatalieM Toilets and Sinks 3 11-03-2013 02:25 PM
Shower into toilet drain FLGSHP7 Toilets and Sinks 9 11-11-2012 07:51 AM
help with clog between shower drain and toilet. NonChalant Drain and Sewer Cleaning 11 03-14-2012 08:38 PM
Please help, shower leaking under toilet have tried everything! kinnz03 Showers and Tubs 2 06-14-2011 12:09 AM
shower clunking when toilet flushed telegirl General Plumbing Help 1 01-19-2011 07:52 PM
