Old 02-22-2010, 06:33 PM   #1
Default Rock substance
My master shower has been draining slowly, so i got a auger and started working and nothing came out and i cant go past one point in the drain. I went out side to the clean out and there is a brown hard as rock substance in there so im wondering if thats what im hitting the main clean out is 10 feet away the house was built in the 60's any help is greatly appreciated im willing to try anything
rando is offline   Reply With Quote
Old 02-23-2010, 02:44 PM   #2
Administrator
Austin's Avatar
So it's only at the trap?
Old 02-23-2010, 03:56 PM   #3
I have always been an advocate with doing work around the house by myself. One reason is that I learn by my own mistakes, and another reason is that I save lots of money. I also know when it is time to throw in the towel and have a professional take a look at the problem. If you have fragile pipes and burst thru one, you will have to get the pipe repaired, at a cost which would be atrocious.
With this being said, I would recommend having a professional plumber with a camera system take a look inside your pipes, and find out what type of obstruction you have.
Good luck!
Old 02-24-2010, 04:58 PM   #4
it is at the bottom of the connection of the celan out and the pipe going in the house if thats there im wondering if it in the pipes further i think i will get a pro to do it i am going crazy lol
Calcium, rock substance
