Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Drain and Sewer Cleaning > Pop-Up Drain Stopper with "D" Cut/Half Moon
Old 12-28-2012, 08:41 PM   #1
Default Pop-Up Drain Stopper with "D" Cut/Half Moon
Hey guys,
Sorry if this has been posted before, but I thought I was making good headway taking the knob off and expecting to see a shaft that I could simply unscrew with a phillips and take the stopper completely off. Instead I found what looks like a "D" Cut/Half moon key hole. Images attached.
My question is how do I get this damn thing off? Looking down that keyhole, I don't see any spot where I can grab onto with a screwdriver or a needle nose (if I even get can one down there).
Any help you guys can send my way is appreciated, thanks in advance.
FF_IN_MN is offline
Old 12-30-2012, 02:44 PM   #2
Liked 123 Times on 111 Posts
Likes Given: 70
While holding the stopper up try to unscrew it.
Old 12-30-2012, 07:44 PM   #3
What is in the pictures is what was revealed after I had already unscrewed the knob. The "D" cut piece is well attached to the stopper itself.
Anybody have any other ideas?
FF_IN_MN is offline
Old 12-30-2012, 07:56 PM   #4
Likes Given: 70
Like I said hold the stopper up and unscrew it. It should unscrew from the shoe.
phishfood Likes This
Old 12-30-2012, 08:06 PM   #5
Liked 62 Times on 54 Posts
Likes Given: 15
Yeah if that doesn't work, some have screws in the side of the stem. I think johns right though, lift up and try and un thread it. I have never came across this type before
Old 12-30-2012, 08:30 PM   #6
Likes Given: 70
I believe what the D-slot is for is a tool to unscrew stopper. But the stopper must raised for it to unscrew. I am not 100% sure of this but it's worth a try.
Old 12-30-2012, 09:20 PM   #7
Likes Given: 15
Makes sense to me John.
Old 12-31-2012, 12:18 AM   #8
Unscrew what? That raised part? Is welded on there.
FF_IN_MN is offline
Old 12-31-2012, 12:23 AM   #9
Got it figured out...the stopper had to be in the plug/stopped/lower/down position to unscrew it. Thanks for the help.
FF_IN_MN is offline
Old 12-31-2012, 12:27 AM   #10
Likes Given: 15
I think what John meant was if you lift it up and maybe put a slotted screw driver into the half moon, the whole piece should come out. If it doesn't come out then it my be stripped or corroded on. If you get really desperate you could try going underneath and prying, I wouldn't go too crazy cause it may disturb the putty in the drain and cause a leak. It's kinda hard to diagnose some stuff online, even though its something as simple as this, sometimes you need to physically be there to be able to do it and try different methods based on what you see. But give those ideas a shot and see how it goes, best of luck!
2" drain pipe to 1.5" sink pipe Bogucki General Plumbing Help 3 10-27-2012 04:18 PM
Adjustable "Metric" and "SAE" wrenches? havasu Plumbing Tools and Equipment 3 04-12-2011 06:58 PM
Outside spigot with plastic "winterizing" piece causing leak thunderbry General Plumbing Help 2 06-19-2010 01:09 PM
Vice President Joe Biden or Jeff Dunhams "Walter" SilverBack4Jack General Discussion 6 01-30-2010 12:53 AM
