Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Drain and Sewer Cleaning > Old house , clogged shower. HELP!!
Old 11-12-2013, 05:13 PM   #1
bachelor23
Default Old house , clogged shower. HELP!!
I'm renting a small house that is over 100 years old, but has PVC for the drains, and recently the shower drain has been acting like its possessed. It first started as just a slow drain and then began to clog completely. I would flush the toilet and it would gurgle and fill with nasty water, I would use the bathroom sink with the same result. Suddenly the toilet stopped effecting it, but the sink closest to it still fills it with nasty water. I've tried Master Jack and it just made things worse ( and nastier ) I've bought a snake but can't seem to get to the clog, it just stops dead 10 ft in. What do I do? HELP!!!
bachelor23 is offline
Old 11-12-2013, 11:34 PM   #2
Liked 384 Times on 324 Posts
Likes Given: 549
The landlord needs to call a drain cleaner or a plumber who is experienced in drain cleaning to snake the line. You need to the proper equipment and some experience using it to do a safe, effective, and thorough job of cleaning a drain.
plumber78 Likes This
Old 11-26-2013, 06:13 PM   #3
bachelor23
I'm trying to avoid that route, considering I'm on low income. I've heard the vent pipe on the roof might be clogged with debris and snaking that might solve my problem. Is this a viable option?
Old 11-27-2013, 12:08 AM   #4
Likes Given: 549
You mentioned that you are renting the house. Normally, clogged drains are the owner's responsibility, unless it can be proven that you have abused the drains by introducing things that shouldn't be.
A clogged vent is rather rare, and almost never the cause of a slow drain.
clogged cast iron house trap dave56 Drain and Sewer Cleaning 2 03-24-2012 05:31 PM
1923 Old Main House Trap Clogged and Inaccessible MarkMark Drain and Sewer Cleaning 6 02-08-2012 08:47 PM
Shower, new house... problems! down2earthlv Showers and Tubs 2 01-31-2012 12:46 AM
Shower water not as hot as rest of house lacey302 General Plumbing Help 1 01-29-2012 04:31 AM
Clogged Tub / Shower Drain ttibsen Drain and Sewer Cleaning 6 03-23-2011 08:00 PM
