Old 01-11-2010, 04:23 PM   #1
Keith's Avatar
Default Live Cultures
Anyone actually know if the various live bacteria, enzymes type products are beneficial to stripping the pipes of material?
Register Now!
Keith is offline   Reply With Quote
Old 01-12-2010, 09:47 AM   #2
Check RootX : Home Good people in the know.
Dennis/Ohio is offline   Reply With Quote
Old 01-12-2010, 12:22 PM   #3
Enzyme cleaners cling to, and eat, organic clogs. In my area, Draincare is a popular product. People seem to use it more than any other product. I have never heard Riddex claim it will clean the pipes, only help the septic tank.
Old 01-13-2010, 01:48 AM   #4
Always Learning.....
SilverBack4Jack's Avatar
We sell a product called Bio-clean. It is suppose to help with buildup. I recommend it as a maintenance solution. It will not open a clogged drain but it will help with slow drains if applied correctly. It isnt a quick solution but is helpful as I said with maintenace issues. Hope this helps.
Bio-Clean - the #1 natural drain cleaner for home and industry
SilverBack4Jack is offline   Reply With Quote
Old 01-15-2010, 08:40 PM   #5
Everything leaks
Dunerunner's Avatar
What happened to the old Draino Crystals that heated up in the drain when you added a little water. That stuff worked great!!
Dunerunner is offline   Reply With Quote
Old 01-15-2010, 08:53 PM   #6
Water well,and septic guy
waterwelldude's Avatar
Its just like anything else that works. They stop maken it.
Travis
Old 01-16-2010, 03:28 PM   #7
As is human nature, people figured if one capful is good, two capfuls are better. later they found that the liquid to granule mixture was too dry, and the granules turned into a 'concrete" consistancy in the trap. The stuff was so caustic, it killed all the bacteria in the septic or ate holes in the pipe.
Old 01-16-2010, 04:36 PM   #8
Dune, I would say this is probably the biggest reason: http://www.zepcommercial.com/msds/ZUCRY2.pdf
It looks like Zep still makes it, but I would hate to see the numbers on how many people (John Q. Public... Dee D Deeeeee!) have gotten caustic burns from that stuff over the years.
Highpower is offline   Reply With Quote
