The older trap clean-outs had a rubber "O" ring. This may have dropped off, or disintegrated when you removed the plug. Try teflon tape or joint compound (pipe dope) on the threads. As a last resort, draw a piece of heavy string through a candle to coat with wax. Wrap the threads of the plug once or twice with the string and install the plug.
