A leak is coming through the ceiling from the second floor, tenant took a shower upstairs , the pipes are Z shaped.
I was wondering ,if there is a Mix or a Fluid that I can pour into the drain pipe to fix the hole in the pipe ? or do I have to break down the Sheetrock and locate the hole ?
Do I need to create a brand new drain line ? I am grateful in advance for any ideas or advice on this issue.
