06-25-2011, 10:48 PM
Found dirty water in my kitchen sink. Help!!!
Hi everybody,
My neighbor's kitchen sink and my kitchen sink are separated by a wall. Recently, I've noticed water goes down the drain slowly. When both of us turn on the water at the same time, my water wouldn't go down at all.
Worst, when my neighbor turns on the garbage disposal, the dirty water end up in my sink. It's kinda yucky, the smell and everything.
So, I went to Home Depot and bought a "snake" that came with an electrical drill. The package cost me $90. I guess my question is, can I go ahead and apply the snake? Or should I try something else?
06-25-2011, 11:57 PM
If the drain piping arrangement is as I suspect, the snake will probably cross over and come up in your neighbor's kitchen sink drain.
From what information I gathered from your post, I am guessing that you will end up needing to hire a professional to take care of this one. If it were just your sink backing up, you might be able to clear the backup, but it is very likely that the two drains are connected with a drainage cross, allowing the snake to travel across the fitting instead of being forced to go down the drain pipe to clear the clog.
06-26-2011, 12:25 AM
My heart sunk as I was reading this response. Does this mean I have to go back and return the snake & power drill to Home Depot? I'm hoping there's a way to get the snake down the drain and not end up in my neighbor's kitchen drain? Do you think you can provide a diagram on this "drainage cross"? I can't visualize it.
06-26-2011, 02:59 AM
I have no skill with whatever programs would allow me to draw a diagram. But imagine a lower case t, with the bottom leg of the t being the drain that is shared by your and your neighbor's kitchen sink. The upper section of the t is the vent for the drains, and the side branches, or arms, are the drain pipes leading to the sinks. Now think of the snake going down one of the branches. You should be able to understand how the snake might cross the t and enter your neighbor's drain pipe.
Again, I don't KNOW that this is the situation you are facing. But from what you have described, this seems to be the most likely case. There are ways to clean such a drain, but it requires a professional to be done safely.
06-26-2011, 04:20 AM
journeyman plumber
When you are trying to snake drain put cable in slowly and use a light and make sure it goes down actually watch cable it will take a couple times you will get it
06-26-2011, 04:22 AM
journeyman plumber
It's like a actual cross four connections. One on top bottom two side each unit con nets to side snake goes straight bend tip to go down
06-26-2011, 06:27 AM
Does it look kinda like this?
(photo attached)
06-26-2011, 01:49 PM
Yes, that is pretty much what I am envisioning.
06-26-2011, 07:36 PM
Please see another diagram below (photo attached).
If I were to attach a shield to a stick (see red), push it into the other end of the shared pipe, would my snake (see green) be able to go down the pipe easier? The shield would block the snake from going into my neighbor's drain. Once the snake hits the shield, it would have no other ways except going downward.
Just a thought popped up last night.
(photo)
08-10-2011, 01:43 AM
Master Plumber
I would be very wary of putting things into the drain that could break off or get stuck in there. If you take the end of your snakes cable and a pair of pliers, you should be able to bend the end into a sharp curve. Then you can just feed the cable in with the curved end pointed down and manually "shove" the curved end into the drain's bottom and make the first turn like that. Also, I would HIGHLY advise that you go talk to your neighbors about what you're doing and make sure they're not running the kitchen sink while you're snaking it out. Otherwise, you might just get very wet. Hope this helps.
