The drains in my second floor bathroom have been acting up for while now; at some point 6 months to a year ago the shower drain was clogged, and the tub would fill with water and take hours to drain after a shower. I eventually cleared that up with one of those plastic zip it tools, or so I thought. The shower drain was working fine, no apparent back up at all.
Recently, in the past few weeks, the pipes have been making a kind of high pitched, whining noise whenever the toilet was flushed or water ran through the tub drain. Didn't do anything about it, because the drains seemed to be flowing properly... Today I flushed the toilet, and the drainage came up into the tub. The bowl slowly drained, gurgling at the end, and eventually filled back up. Once the toilet was completely drained, the tub drained easily, and if you run water through that drain, it seems to be clear (does make the noise though.)
The fixtures are all against the same wall, right next to each other, with the toilet in the middle. Since the shower and sink drains seem to be ok, and there's no trouble at all with any of the downstairs fixtures, I'm *guessing* it's some kind of clog in the main stack, hopefully not too far away from the toilet. I read a bunch of threads about similar problems, and looked at some diagrams, so I'm gonna try and clear it out with an auger by myself, before I consider calling a pro. Does this sound possible, and/or easy? Also, I'm a little concerned about getting into the tub drain, if that is necessary. There is a metal fitting inside the drain, after you take the cap off, and although I haven't tried any tools on it yet, it appears to be in there pretty securely. I've included a picture of that..
Any suggestions would be very much appreciated! Thanks in advance!
