Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Drain and Sewer Cleaning > clogging main pipe
Old 01-24-2011, 09:22 PM   #1
Bob
Default clogging main pipe
I have a repeated clogging issue in the main sewer line it is easy enough to clear but I would like to prevent it from happening as much as possible I have been told that the brand of paper we use is part of the problem is this possible? if so what brands are good bad or otherwise thanks for your input -Bob
Bob is offline
Old 03-14-2011, 04:58 AM   #2
Banned
Send a message via Skype™ to rfdevere
this is not the case - toilet paper is toilet paper, a properly working sewer line should be able to facilitate kitchen roll or babywipies! the problems like this occur when there is a design fault (gradient) or breakages, roots, a dip or sag etc in the line. These problems cause the water to leave the solids and cause this.
Maybe rent a cheap camera to see what your working with? then at least you know
rfdevere is offline
Old 03-14-2011, 06:12 PM   #3
Bob
thank you for the input something didnt sound right in their explanation
Bob is offline
Old 04-01-2011, 12:22 AM   #4
HELLO I WORKED ON SOME JOB LIKE YOUR THAY PUT IN NEW LOW FLOW TOILET AND USED THICK PAPPER AND NOW THAY USE THIN PAPPER AND HOLD TOILET LEVER DOWN FOR MORE WATER FLOW AND PUT BABYWIPIES IN TRASH THAT WILL PLUG IT UP BUT IF YOU HAVE ROOT OR BAD SLOP DIFRANT STORY FROM jeff
permoliner is offline
Roots in sewer pipe to main, Hydro-jet?? DavidN Drain and Sewer Cleaning 40 02-25-2013 09:19 PM
Toilet Paper Clogging Up fastballbaker Toilets and Sinks 5 03-02-2012 03:05 AM
Toilet PVC drain pipe came loose from pipe that leads to sewer. tireshark General Plumbing Help 6 08-02-2011 01:20 AM
Need to cap off an iron water pipe 3/4 for renos, do I need to thread the pipe? drchalifax General Plumbing Help 1 05-20-2011 09:04 PM
Main pipe in sink is dripping Zachwulf Toilets and Sinks 2 05-30-2010 01:28 PM
