Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Drain and Sewer Cleaning > Best DIY Snake for Bathroom Sink
Old 12-24-2012, 02:52 PM   #1
Solid
Liked 3 Times on 3 Posts
Default Best DIY Snake for Bathroom Sink
Happy Holidays Everyone!
So, My upstairs bathroom sink drains terribly slow, and now has standing water. I've taken apart the trap and it is very clean, and I also tried using a wet vac to clear any block, with no luck. Here is a picture of the plumbing (not sure if this will help):
This may look familiar to some of you - that's because I recently replaced leaking galvanized nipples with brass you see here (thanks for the help!). I noticed that the drain for this sink is also galvanized pipe, and I have a feeling that the inside of this pipe will be just as clogged up with black stuff as the old nipples were. I have about 3' - 4' from the PVC/galvanized junction to the main stack (behind the wall). Can you guys recommend a tool to clear this line that I can pick up at one of the big box stores, that actually works?
Solid is offline
Old 12-24-2012, 06:04 PM   #2
stevemachine
Liked 89 Times on 78 Posts
Likes Given: 91
I have one and use it professionally for bathroom sinks. This puppy can go right through the trap. It's good for bathroom sinks but its a bit small for kitchen sinks but I have used it before. This one is at Home Depot. Personally I cut the head off and bend the end and use it that way. Tin snips will cut it off
Old 12-24-2012, 06:10 PM   #3
Solid
Thanks Stevemachine. I guess the title of this post should've been:
"Least Expensive Thing I Can Buy At Home Depot on Christmas Eve to Clear a Completely Blocked Drain before My Relatives Show Up"
I saw that on their website, but I really didn't want to spend that much right now. Do you think any of the small Ridgid hand crank (or, drill-adaptable) units would do anything?
Like this for example:
Solid is offline
Old 12-24-2012, 08:07 PM   #4
stevemachine
Likes Given: 91
Well I've used hand snakes before. Sometimes they work and sometimes they just aren't strong enough. If its drill adaptable then I would say go for it and it should at least get it running
Old 12-24-2012, 08:10 PM   #5
stevemachine
Likes Given: 91
Running=draining is what I meant haha
Old 12-24-2012, 09:46 PM   #6
mesaman
Liked 2 Times on 2 Posts
Hand crank or drill can get the job done. However, depending on the clog sometimes you need a snake with some horse-power. Check with your local home depot to see if they have any snakes available for rent
My company - http://www.themesaplumbers.com
mesaman is offline
phishfood Likes This
Old 12-24-2012, 10:20 PM   #7
stevemachine
Likes Given: 91
Yeah agreed, maybe a rental could be your best bet. Just be super careful if you use a drill or power one. There's always the possibility of the cable binding and catching your fingers in the process. But you're usually pretty safe with the smaller drill ones as opposed to the big main line machines
Old 12-25-2012, 06:34 PM   #8
Solid
Thanks for the replies everyone, and Merry Christmas!
Hmmm, I think I found the problem!
100% blocked
I ended up making it to Home Depot 1hr. before closing, and picked up the last Ridgid Power spin that they had on the shelf:
It has the option to attach to a cordless drill, but I just used the hand crank. It pulled out some hair, but mostly it was blocked up with black slime - the same stuff that I found in the Nipples that I replaced. I'm assuming that this is from the galvanized pipe? Not sure. It works just fine now.
I'm planning on opening up the wall in this area anyway, so I was going to try to replace this small section with PVC - depending on how it attaches to the main behind the wall. When I get to that point, I will post a new topic. Thanks again everyone!
Solid is offline
Old 12-25-2012, 08:40 PM   #9
stevemachine
Likes Given: 91
Yeah galvanized is awful whether it be drainage or water supply. Everything sticks to the wall then it closes itself off. Glad to hear you got it clear!
Old 12-26-2012, 08:24 AM   #10
DetroitRob
DetroitRob's Avatar
Liked 11 Times on 11 Posts
I like that little ridgid shop vac looking snake. I picked one up on a whim, and I use it quite a bit. There is a bushing in the drum where the cable feeds through that needs to be occasionally cleaned/lubed or the cable won't pull out easily. Fyi.
DetroitRob is offline
Odor from bathroom sink Novatech General Plumbing Help 1 10-17-2012 02:39 PM
Help please with bathroom sink bjack Toilets and Sinks 2 04-28-2012 05:08 PM
Sink clog too far to snake! Biller Drain and Sewer Cleaning 9 08-17-2011 07:09 PM
EZ way to clear slow running bathroom sink drains without a wire snake. 5shot Drain and Sewer Cleaning 12 05-15-2011 01:50 AM
