Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Drain and Sewer Cleaning > bathtub pop-up drain clogs
Old 12-07-2012, 05:20 PM   #1
Default bathtub pop-up drain clogs
I have a bathtub drain that has a pop-up stopper... and I need to clean the hair out to often... because of how it's set up you can't put any snakes or even simple hair grabbers through the grate... a bent hanger is what I use but not the best to really get all the hair... so what can I do to improve this?
Thanks
jojodwolf is offline
Old 12-07-2012, 05:52 PM   #2
Liked 100 Times on 90 Posts
Likes Given: 19
You need to go to a local big box hardware store and purchase the bathtub drain screen.
Old 12-07-2012, 06:23 PM   #3
Do they sell plugs this size so that when the wife wants a bath I don't have to screw the metal plug back on.. ?
Old 12-07-2012, 06:43 PM   #4
Likes Given: 19
If the plug needs to be screwed in for a bath, you could always pick up a larger screen and invert it (making a dome) around the drain to catch all the hair. Women's hair and small drains have kept plumbers in business for many years.
Old 12-07-2012, 09:43 PM   #5
Liked 58 Times on 52 Posts
Likes Given: 11
Isn't that the truth. I can't even count how many plugged tubs I've augered full of hair
Old 12-08-2012, 12:39 PM   #6
Liked 66 Times on 56 Posts
Likes Given: 53
You should be able to find a old style rubber tub stopper at your local hardware store
Old 12-09-2012, 02:00 PM   #7
bought a small screen insert... and by removing the screw from the old stopper that can be used when needed
Old 12-23-2012, 02:40 AM   #8
"If it's broken we fix it
I get this all the time from customers.. I've got a few old dental hooks and medical hemostats (like scissors but with teeth), 2 min and I'm done.
If all you take are showers the screen will work, after removing the hair. But I prefer using the drain as it's installed.
House Doc is offline
Old 12-23-2012, 11:30 AM   #9
Liked 116 Times on 106 Posts
Likes Given: 69
Get one of these they work great. Through the drain or over flow.
http://zipitclean.com/
Caduceus Likes This
Old 12-27-2012, 02:33 PM   #10
I bought one of those zip cleans.. but the metal grid in the drain does not let you pull the thing out without extreme force losing the hair on the way out
Bathtub Drain Disaster, Please Help! abbyhope Showers and Tubs 1 07-07-2012 01:59 AM
Holding Tank Pump Clogs dennisl2k079200 Drain and Sewer Cleaning 1 02-17-2012 03:01 AM
Need help before taking off bathtub drain pipe YosemiteJack Drain and Sewer Cleaning 5 12-14-2011 11:09 AM
Bathtub to Shower, Drain HELP pwgsx Showers and Tubs 4 11-22-2010 02:06 AM
Bathtub drain problem bluemax01 General Plumbing Help 2 07-21-2010 10:24 AM
