Ridge Tool Company - Ridgid® Sink Machine Drain Cleaning Gun, K-39 w/ Autofeed - 3/4 in to 2-1/2 in. Reviews, Ratings, Specs & Prices
Previous Product Augers and Snakes
MSRP: $439.00
Company Website: http://www.professionalequipment.com/ridgid-sink-machine-drain-cleaning-gun-k-39-w-autofeed-k39af/drain-cleaners/
Features & Applications:
This Ridgid sink machine gun is excellent for small line cleaning. Opens clogged lavatory, sink lines, urinals, and tub/shower drains. The advanced two-way feed keeps hands off cable – advances & retrieves cable with push of a lever. Perfect for cleaning sinks and toilets without removing traps or clean-out plugs
Features:
5/16" cables best for 3/4" to 1 1/2" lines
Both have slide action chuck for quick locking/releasing of cable.
Advanced two-way feed keeps hands off cable advances & retrieves cable with push of a lever.
Lightweight, easy-to-use, no set up required.
Variable speed power unit rotates cable 0-450 RPM’s.
Two piece twist lock canister with interchangeable inner drum.
Makes cable changeout simple; easy to match the right cable to the job.
Inner drum prevents water leaks and greatly reduces cable flip over.
Drums won’t rust or dent ever.
Drum Capacity: 50' of 5/16" (15m/8mm) or 35' of 3/8" (11m/10mm).
CSA approved.
Specifications:
Drain Line Capacity I.D. (In.): 3/4 to 2 1/2
Chuck Type: Slide Action
Motor Type: Universal
Motor Rating: 115 VAC, Single Phase, 1.1 Amp, 60 Hz
Motor Trigger Switch: Variable Speed, Reversing
Operating Speed (RPM): 0 to 450
Drum Capacity: 50 Ft of 5/16" or 35 Ft of 3/8" Cable
Drum Characteristics: 2 Piece Twist Lock Polyethelene Canister with Interchangeable Inner Drum
Application: Cleans Sinks and Toilets Without Removing Traps or Clean-Out Plugs
Meets / Exceeds: CSA Certificate 1720213
Includes: 5/16" x 25 Ft Cable With Bulb Auger
plumbing, ridgid
