Ridge Tool Company - Ridgid® Drain Cleaning Water Jetter, KJ-1750 - 1-1/4 in. W to 4 in. W Reviews, Ratings, Specs & Prices
MSRP: $3,295.00
Company Website: http://www.professionalequipment.com/ridgid-drain-cleaning-water-jetter-kj-1750-kj-1750-c/drain-cleaners/
Features & Applications:
This Ridgid drain cleaning watter jetter propels a highly flexible hose through 1 1/4" to 4" lines–blasting through sludge, soap and grease blockages. As you pull the hose back, it power scrubs the line, flushing debris away and restoring drain lines to their free-flowing capacity. Actual working pressure of 1750 psi and flow of 1.4 GPM for fast, effective cleaning of lines. Two levels of pulse are standard. Activate the KJ-1750’s pulse action to easily negotiate difficult bends and traps. The H-30 Cart rolls the jetter and hose to the job site. The jetter is easily removed from the cart in seconds for hard to reach drain or for remote storage.
Features:
The 2.0 HP motor draws a maximum of 17 Amps which requires a 20 Amp, 115 Volt circuit.
Thrust propels the hose down the line. You simply guide the hose into the drain.
Duplex pump with corrosion-resistant, forged brass head. New pressure control valve allows quick and easy pressure adjustment.
Reduced number of fittings, hoses and parts minimizes leaks and down time keeping you on the job.
CSA approved.
Specifications:
Drain Line Capacity I.D. (In.): 1 1/4 to 4
Max. Run (Ft.): Up to 200
HP: 2
Motor: 115 VAC, 17 Amp
Pump: Duplex Plunger
Jet Pressure (PSI): 1750
Flow Rate (GPM): 1.4
Application: For Blasting Through Sludge, Soap and Grease Blockages, Power Scrubs Line as Hose is Pulled Back
Includes: (4CW98) 1/2 In x 110 Ft Jet Hose, (4GL58) 1/8 In x 50 Ft Sink Trap Hose, 1/8 In NPT (4CW87) Propulsion, (4CW88) Penetrating, and (4CW99) Drop Head Nozzles, 1/4 In NPT (4CW89) Propulsion and (4CW90) Penetrating Nozzles, Nozzle Cleaning Tool, Nylon Storage Bag, Cart With Hose Reel
plumbing, waterjetter
