Ridge Tool Company - Ridgid® Drain Cleaning Sectional Machine, K-1500 - Low-Profile “B” Frame Reviews, Ratings, Specs & Prices
MSRP: $3,125.00
Company Website: http://www.professionalequipment.com/ridgid-drain-cleaning-sectional-machine-k-1500-k-1500b/drain-cleaners/
Features & Applications:
This Ridgid drain cleaning sectional machine is the finest all-around sewer and drain cleaning machine. One man can easily clean the heaviest blockages – indoors or out. High-speed cleaning gets the job done faster...better. Features a unique, easy-to-use, instant-acting cable clutch maximizes operator control: pull handle down, cable spins at constant 710 RPM and the release handle frees cable instantly, no overrun to loop or break cable.
Features:
Wheels to the job site sets up fast, cleans up fast.
Low-profile frame design will fit most crawl spaces, loads and unloads from truck easily.
Equipped to run, easy to handle, 15-foot sections of 1 1/4" cable to clean 3" to 8" (32m-200mm) lines to 200 feet (61m).
Easy clutch jaw change-out adapts K-1500 to run 15-foot sections of 7/8" (4.6/22mm) cable through 2" to 4" lines up to 175 feet (50-100mm, 53m).
Equipped with 3/4 HP motor; 115V Models.
CSA approved.
Specifications:
Drain Line Capacity I.D. (In.): 2 to 8
Max. Run (Ft.): Up to 200
HP: 3/4
Operating Speed (RPM): 710
Motor: Universal, 115 VAC, Single Phase, 2 Amp, 50-60 Hz, Variable Speed, Reversing
Power Cord: 15 Ft GFI Protected
Application: For Indoor and Outdoor Jobsites
Meets/Exceeds: CSA Certified LR13710
Includes: 7 Sections of (2W354) 1 1/4 In x 15 Ft Sectional Cable (For Total of 105 Ft), (1VUZ8) Left Leather Mitt with Steel Studs, (1VXC3) Straight Auger, (1VXD9) Funnel Auger, (1VXE2) Funnel Retrieving Auger, (1VXC2) 2 1/2 In Sawtooth Cutter, (1VXG4) 3 In Sharktooth Cutter, (1VXE4) 2 1/2 In Grease Cutter, 2 Hex Keys, 12 Ft Rear Guide Hose, Coupling Pin Key, 2 Cable Carriers, Tool Box
plumbing, ridgid
