Ridge Tool Company - Ridgid® Drain Cleaning Drum Machine, K-3800 Reviews, Ratings, Specs & Prices
MSRP: $1,362.00
Company Website: http://www.professionalequipment.com/ridgid-drain-cleaning-drum-machine-k-3800-k-3800/drain-cleaners/
Features & Applications:
This Ridgid drain cleaning drum machine is a powerful, easy to transport, versatile machine for cleaning indoor drains. Requires minimal set-up to clean sink lines, floor drains and roof vents. Rugged, corrosion-resistant molded cable drum won’t dent or rust. The drum tilt adjusts for proper cable feed angle. Inner-drum guards against cable flip-over. Cable drum’s quick-release and built-in hand-holds allow easy cable change and transport. Standard drum capacity is 100' of 3/8" or 90' of 1/2" (30m/10mm or 27m/12mm) continuous length cable.
Features:
3/8" cable best for 1 1/2" to 3" lines up to 100'.
Powerful 1/12 HP Universal Motor spins cable at 240 RPM. When cable hits blockage, motor gears down automatically to deliver more power and enhance operator control.
Tools connect to cable in seconds.
CSA approved.
IW (Integral Wound) cables available. IW cables are slightly stiffer and kink resistant. All IW cables use 3/8" T-200 series cutters.
Specifications:
Drain Line Capacity I.D. (In.): 2 to 8
Max. Run (Ft.): Up to100
HP: 1/12
Operating Speed (RPM): 240
Motor: Universal
Drum Capacity: 100 Ft. 3/8" or 90 Ft. of 1/2" Cable
Application: For Laundry Stacks, Roof Vents and Indoor Floor Drains
Includes: (6A649) 3/8 In x 75 Ft Inner Core Cable, (1VXC6) 1 1/8 In Bulb Auger, (1VXD1) 1 3/8 In C-cutter, (1VXD5) 1 3/8 In Grease Cutter, (1VUZ9) Coupling Pin Key, Pair of Gloves
plumbing, ridgid
