Ridge Tool Company - Ridgid® Drain Cleaning Sectional Machine, K-60 Reviews, Ratings, Specs & Prices
Augers and Snakes Next Product
MSRP: $1,948.00
Company Website: http://www.professionalequipment.com/ridgid-drain-cleaning-sectional-machine-k-60-k-60sp-se/drain-cleaners/
Features & Applications:
This Ridgid drain cleaning section machine is a compact machine for institutional, commercial or residential cleaning. Also ideal for septic tank vacuum truck operators. Small enough to fit into cramped spaces, yet powerful enough to clear tough blockages. Ideal for rooftop vent stacks. Rear handle allows for easy transporting up ladders and onto rooftops.
Features:Unique, easy-to-use, instant-acting cable clutch maximizes operator control.
Push handle down, cable spins at 600 RPM.
Release handle, cable stops instantly, no overrun to kink or damage cable.
Simple adjustment knob allows unit to spin both 7/8" (22mm) and 5/8" (16mm) diameter cable. Adjusts in seconds.
7/8" cable (C-10) cleans 2" to 4" lines through 150 feet.
5/8" cable (C-7, C-8, C-9) cleans 11/4" to 4" lines through 125 feet.
Remove only two bolts to access jaw set for cleaning or replacement. Removal of same bolts provides access to belt drive.
Equipped with 1/2 HP motor.
CSA approved
Includes:
K-60SP Machine.
A-1 Operator’s Mitt.
A-60-12 Rear Guide Hose.
A-62 Cable Kit, includes:
A-8 Cable Carrier.
Five Sections Of C-10, 7/8" Cable, Total 75 Feet.
A-61 Tool Kit, includes:
T-101 Straight Auger.
T-102 Funnel Auger.
T-107 Spade Cutter.
T-125 Retrieving Auger.
T-150-1 Sharktooth Cutter.
A-3 Tool Box.
A-12 Pin Key.
Specifications:
Type: Sectional
Drain Line Capacity I.D. (In.): 1 1/4 to 4
Max. Run (Ft.): Up to 150
HP: 1/2
Operating Speed (RPM): 600
Motor: Induction, 115 VAC, 60 HZ
Power Cord: GFI Protected
Clutch Type: Instant Acting
Features: Rear Handle For Easy Transporting, Adjustment Knob To Change From 5/8" To 7/8" Cable, Rubber Feet For A Sloid Platform
Application: For Use in Homes, Industry and Institutions
Meets / Exceeds: Approved To UL Standards, NRTLC
drains, ridgid, tools
