Plumbing Forum - Professional & DIY Plumbing Forum > Reviews > Plumbing Tools > Augers and Snakes > Ridge Tool Company - Ridgid Drain Cleaner Model K-400
Old 01-14-2010, 07:53 PM   #1
Keith's Avatar
Liked 3 Times on 3 Posts
Default Ridge Tool Company - Ridgid Drain Cleaner Model K-400
Features & Applications:
The K-400 Ridgid Drain Cleaner offers several unique, user-friendly features to make the toughest drain cleaning jobs easier and hassle-free. Designed with a sleek profile, the K-400 is a great fit for drain cleaners, service plumbers, facility and institutional maintenance departments and property management companies. It is designed for 1-1/2" to 4" (32-100mm) drain lines.
Features:
Integrated Transport Cart allows for easy movement to and from the job site. Heavy-duty, over-molded rubber wheels easily navigate over bumps and up stairs.
Integrated Telescoping Handle provides high-handle height during transport. Handle locks in low position during drain cleaning operation or during transport to minimize space requirements.
Cable Control System causes the drum to stop spinning when the blade becomes lodged in a blockage, limits potential for cable to flip over in the drum and helps to indicate to operator when blockages are encountered.
Solid Core Cable optional 3/8" or 1/2" Integral Wound (IW) solid core cable that is rugged and kink-resistant. Each size comes in several lengths and utilizes a variety of the RIDGID quick-connect cutters.
Spec Summary:
Drum Capacity:
100' of 3/8" Diameter Cable (not included)
75' of 1/2" Diameter Cable (included)
Motor:
Type: 115V/60 Hz, Reversible, Split Phase
Rating: 1/3 HP @ 1725 r/min
Amps: 6.7
Weight (Machine Only):45 lbs.
Length:21" (24" with Autofeed)
Width:17"
Includes:1/2" x 75 ft. solid core cable
Register Now!
Keith is offline
plumbing, ridgid
