Ridge Tool Compan - Ridgid® Drain Cleaning Water Jetter, KJ-3000 - 2 in. W to 8 in. W Reviews, Ratings, Specs & Prices
MSRP: $5,595.00
Manufacturer: Ridge Tool Compan
Company Website: http://www.professionalequipment.com/ridgid-drain-cleaning-water-jetter-kj-3000-kj-3000/drain-cleaners/
Features & Applications:
This Ridgid drain cleaning watter jetter gives you 3000 psi actual working pressure to handle large commercial and industrial applications. This jetter propels a highly flexible and lightweight hose through 2" to 8" lines – blasting through sludge, soap, grease, and sediment blockages. As you pull the hose back, it power scrubs the line flushing debris away and restoring drain lines to their full, free-flowing capacity – all without the use of harmful chemicals. Actual working pressure of 3000 psi and flow of 4.0 GPM for fast, effective cleaning of lines. Hose with nylon braid provides significant weight reduction and increased flexibility – all without reducing strength. Allows the thrust to propel the hose further down the line. With the KJ-3000’s removable hose reel, there is no need to purchase expensive portable hose reels. Completely remove the hose reel to ease loading onto service trucks. Simply rotate the hose reel forward to gain full access to the engine’s gas tank and air filter. In the heavy-duty 3000 psi jetter category, the Ridgid KJ-3000 is one of the most maneuverable jetters on the market. The unit, on its unique two-wheeled cart, easily fits through standard size doors and can negotiate tight turns with the greatest of ease.
Features:
Activate the KJ-3000’s pulse action to easily negotiate difficult bends and traps.
Triplex pump with corrosion-resistant, forged brass head. Gear reducer allows pump to run at slower (optimal) speed. Reduced number of fittings, hoses and parts minimizes leaks and downtime – keeping you on the job.
Power wash package and chemical injector system cleans cables, tools, and other heavily soiled equipment.
13 HP Recoil start gasoline engine starts easily. Features: ON/OFF switch; choke and throttle controls; easy access oil fill and dip stick.
Specifications:
Drain Line Capacity I.D. (In.): 2 to 8
Max. Run (Ft.): Up to 200
HP: 13
Engine: Recoil Start, Gasoline
Jet Pressure (PSI): 3000
Flow Rate (GPM): 4.0
Application: For Blasting Through Sludge, Soap and Grease Blockages
Includes: Hose Reel With 3/8 In x 200 Ft Jet Hose, 1/4 In NPT Propulsion, Penetrating and Root Cutting Nozzles, Foot Valve, Nozzle Cleaning Tool, Wash Wand, 3/8 In x 50 Ft Jet/Wash Hose, Chemical Injector
plumbing, ridgid, waterjetter
