Go Back   Plumbing Forum > Specific Plumbing Discussion > Manufactured Home Plumbing
Old 01-06-2010, 10:02 PM   #1
Default to get started...
Things to remember:
If the fixture from Home Depot doesn't fit, check with the local RV dealer. If you have to replace a faucet or fixture, consider using standard plumbing. Later repairs will be easier as parts are more readily available.
If you use PEX piping, Sharkbite is your friend.
Standard 1/2 inch couplers do NOT fit on the RV/mobile/manufactured fixture and will strip the threads; check out Flare-It fittings.
Nuthin is offline   Reply With Quote
Sharkbite, manufactured homes, RV dealer
« - | Bad smell »
