Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > What would you do?
Old 10-25-2013, 06:24 PM   #1
In_over_my_head
Liked 2 Times on 2 Posts
Likes Given: 2
Default What would you do?
How would you attempt to fix this fluster cluck? I am putting in a new sink base since the old one was damaged due to a roof leak. The leak has been repaired and the old drywall has been removed and replaced. I know I need to move all the piping forward so it will be able to come up through the new sink base. However, there is a outside faucet coming off this mess (it was like this when I bought the house). Is there any way I can retain the faucet and still make this somewhat up to code standard? Most things in this house are not up to code but I am slowly redoing everything so that it is. I really need to get this finished today so I can have my kitchen sink functional again. Please do not suggest hiring a plumber as it is a bit cost prohibitive at this time.
In_over_my_head is offline
LarryL Likes This
Old 10-25-2013, 07:12 PM   #2
m-plumber
Liked 2 Times on 1 Posts
Is that mold on the wall? Cut the plumbing out and start new
m-plumber is offline
2
People Like This
Old 10-25-2013, 09:13 PM   #3
In_over_my_head
Likes Given: 2
It was surface mold on the wall from a roof leak. All that has been removed and replaced with new. The studs behind the sheetrock have also been treated but no mold was found.
LarryL Likes This
Old 10-25-2013, 09:15 PM   #4
In_over_my_head
Likes Given: 2
Also is it possible to keep the exterior faucet that runs off of this piping?
Old 10-26-2013, 02:44 PM   #5
LarryL
Likes Given: 6
I agree. Cut that entire mess out and take your time running all new.
Are those lines coming up from the basement? I am assuming you dont need the outside faucet for the rest of this year??? (cut it, seal the hole, and look at relocating that line next spring????)
LarryL is offline
In_over_my_head Likes This
Old 10-27-2013, 04:28 AM   #6
JamesWalnut
I agree also to start over. Keep as much of the drain pipe you can.
JamesWalnut is offline
LarryL Likes This
