Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > what is the order to connect the pipe
Old 03-17-2013, 04:45 PM   #1
Default what is the order to connect the pipe
Hello all,
I am interested in how the gas pipe lines are connected in my house.
Please see the attached image.
Assume I need to reconnect the pipes from scratch, Here is my question
What is the order I should put the pipes?
For example, if I install pipe 1 first, then 2, then 3, then 6 and 7.
How can I tighten 5, 4 and 3 at the same time? I am not sure how the bolt 4 works. It seems to me if I tight 3-4 then I will loose 4-5.
Another question is how I can make sure the order of 3-2-6 is in the up-down order. What if I finally can get 6-2-3 up-down order. what else I can do?
What is the trick here?
q0987 is offline
Old 03-17-2013, 04:58 PM   #2
Liked 101 Times on 91 Posts
Likes Given: 19
#4 is a union, with reverse threads on one side of the coupling, and should be your last connection. Yes, you start with #1, then the tee (#2) then work down securing #6 and #7, tighten the #3 nipple, then finally the lower half of the union #4, then secure the top half of the union (#4) to #5, then tighten the union center (#4). Another option is to leave #7 until the last connection, so as to allow the gunk and crap to be allowed to fall out before securing.
Zanne Likes This
Old 03-17-2013, 06:36 PM   #3
I saw this video
where the guy only tighten the lower and upper parts of the union. I never saw him tighten the center part.
Is there anything wrong?
Thank you
q0987 is offline
Zanne Likes This
Old 03-18-2013, 12:13 AM   #4
Likes Given: 19
There is nothing wrong with what I saw from his installation, but I can assure you he tightened the union either prior to or after the installation. The video did not show what he used to complete the installation, and I can only presume he used a flexible line.
Zanne Likes This
Old 03-20-2013, 06:33 PM   #5
Originally Posted by q0987 View Post
Hello all,
steps of rejoining gas pipe in your house:
1 Extend your existing gas line by fitting the valves and pipe lengths you need to add a gas line that will reach your new appliance.
2 Use a flexible pipe to connect the end of your new gas line to the appliance.
3 Spread a mixture of water and dish liquid over each seam in your gas line. If bubbles appear, you have a leak. Unscrew that section, strip off the pipe glue, and reattach with new sealant.
4 Turn the gas back on by returning the valve to parallel to the incoming pipe. Test your appliance to ensure the gas is flowing properly.
smithrick420 is offline
Zanne Likes This
Old 03-22-2013, 12:41 AM   #6
:0)
PioneerPlumber's Avatar
Liked 21 Times on 21 Posts
Likes Given: 5
I find this whole thread a bit unsettling...
Go to Home Depot and play around with those same fittings. That should answer all of your questions.
It should be pretty clear as to which area to start with and where to finish.
The purpose if the union is to join two independent sections of piping together. Th last connection will be the union. (With pipe dope on the inside face I hope...)
-Daniel
PioneerPlumber is offline
phishfood Likes This
Old 03-25-2013, 01:33 AM   #7
Liked 63 Times on 48 Posts
Likes Given: 37
note: sealant is not to be used on the face of the ground joint of a union. threads, yes. face, no.
johnjh2o Likes This
Old 03-26-2013, 02:47 AM   #8
:0)
Likes Given: 5
Any connection that seals between two metal surfaces (brass, copper, steel, etc) including compression, flare or unions needs to have pipe dope applied to the face or surface area that is sealing the joint. The threads of a union do not seal the joint, they draw the two separate pieces together.
I also dope the threads which allows the fitting to be more easily disassembled in the future.
I understand that "by design or in theory" you are not required to do so and that the design of the fitting should not need it, but lets be real here... Any plumber with experience knows this is needed.
Thoughts?
-Daniel
Zanne Likes This
Old 03-26-2013, 03:18 AM   #9
Liked 123 Times on 111 Posts
Likes Given: 70
Thoughts?
I have been doing it for 50 years and never used pipe dope on ground joints.
johnjh2o is online now
Zanne Likes This
Old 03-26-2013, 04:11 AM   #10
Liked 62 Times on 54 Posts
Likes Given: 15
If its residential you can blow through a straw more pressure than what comes out of your gas lines. 7" w.c is so minimal that I've never had to dope them. I don't have a ton of experience by any means but in 3 1/2 years I've never had an issue, but that's just my 2 cents
Zanne Likes This
What's the right order? DIY_Plumber General Plumbing Help 7 02-02-2013 12:17 AM
How to connect fittings to a fiberglass tank. Joelk General Plumbing Help 5 04-26-2012 12:46 AM
Quick-Connect adapters TheBus General Plumbing Help 1 10-29-2011 12:21 AM
Quick-Connect adapters TheBus General Plumbing Help 2 10-17-2011 10:38 PM
Can quick-connect fittings be reconnected? kotterr General Plumbing Help 4 07-14-2011 05:14 AM
