Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > well problem?
Old 09-01-2013, 05:28 PM   #1
iansky
Default well problem?
i woke up today with very little water pressure in all of the sinks/showers in my house. only a very tiny stream came out, and over the day even the stream stopped.
i checked the shut off valve to my house to make sure it wasn't off, and opening it a bit more made the water flow again, but weaker than normal. the water stopped flowing again after awhile so i checked the well water tank outside and the pressure on the gauge reads 65.
i have absolutely no knowledge of plumbing...so can anyone give me suggestions as to what is wrong and if it is "DIY"-able?
thanks!
iansky is offline
Old 09-01-2013, 06:18 PM   #2
Liked 385 Times on 325 Posts
Likes Given: 555
Do you know if there is a water filter on your water supply line?
Also, tap the side of the gauge to make sure it is not stuck. And if there is a hose faucet by the well tank, check to see if you have water pressure there.
Old 09-01-2013, 06:27 PM   #3
iansky
ah! the gauge was stuck, tapping it made it read 0.
so maybe it needs a new pump? there is a hose line attached and no water is flowing, and i don't know if it has a filter, how would i check?
iansky is offline
Old 09-01-2013, 06:41 PM   #4
iansky
also, the air pressure on the valve at the top for the bladder is at 20psi.
iansky is offline
Old 09-02-2013, 02:26 AM   #5
Likes Given: 555
Sometimes the pressure switch will stick. While goofing with it may bring it back to life, that is dangerous, as you are playing with 220 volts of electricity.
If there is no filter present at the well, and you don't have pressure there, then a clogged filter is not your problem.
A bad pump may be your problem, but it is usually a bad pressure switch or control box.
Old 09-02-2013, 01:18 PM   #6
iansky
well messing around with the electronics or pump itself is beyond me so i'll go ahead and call a repair man. thanks for helping me narrow down the problem!
iansky is offline
Old 09-03-2013, 01:35 PM   #7
speedbump
Liked 47 Times on 46 Posts
Likes Given: 13
One easy thing to try is tapping on the pressure switch with the cover still on. You can't get shocked that way and if you have a bug between the points, sometimes a little tap is all it takes to burn it enough to get the pump to come back on.
speedbump is offline
goulds pump problem or well problem? gg05 Pumps and Wells 3 05-04-2012 12:36 PM
