Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > water starts great then stops - noise in wall
Old 02-04-2014, 02:26 PM   #1
rikb53
Default water starts great then stops - noise in wall
we do not have a well just regular city water here in houston.
but one of my bathrooms - i turn on the faucet (single) on the cold water side and the cold water comes out great for about 5 seconds - and then just stops short.
i hear a moaning noise in one of the walls.
it doesn't happen when the faucet is turned to hot water.
and when u turn the faucet to cold water - BUT ONLY OPEN IT UP 1/2 WAY - no issues -
it only chokes when you open it up all the way.
as soon as you do that then, it stops to a dribble and the pipes behind the wall vibrate and hum.
it's like 'full throttle' is the issue.
you can leave it on all day only if it's half way. has anyone ever heard of this?
thanks again for any suggestions.
rik
rikb53 is offline
Old 02-05-2014, 01:20 AM   #2
Liked 384 Times on 324 Posts
Likes Given: 549
It sounds as though a washer is loose. I would start by looking at the supply stop valve under the sink.
phishfood is online now
johnjh2o Likes This
Old 02-05-2014, 01:58 PM   #3
rikb53
will, do - thanks again for the help
rikb53 is offline
Hot Water Tank Noise karnold Water Heaters and Softeners 4 08-29-2013 01:01 AM
pressure loss + pump stops + draws power hauker Pumps and Wells 8 11-28-2012 04:46 PM
Water Thumping Noise russincincy General Plumbing Help 6 07-30-2012 12:34 PM
I was having a great day until........ Otahyoni General Discussion 68 09-30-2011 04:29 PM
Flow randomly stops, clean water now discolored and slight metal taste grashopa General Plumbing Help 1 10-10-2010 08:33 PM
