Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Water softener
Old 05-09-2010, 01:29 AM   #1
Default Water softener
I have hard water and a slight sulfur odor in the water. Will a water softener solve both problems? Or do I also need an odor filter?
Thanks,
Rocky
RockyRR is offline
Old 05-10-2010, 03:36 PM   #2
Liked 24 Times on 24 Posts
Likes Given: 11
No, a softener will not remove the sulphur odor. The odor is a gas and has to be let out of the water before getting to your faucets.
We do this with an air pump and a galvanized tank under pressure. Some people use aerators. I don't like them because they are unsanitary. A lot of treatment guys use chlorinators to kill the odor. I personally don't like injecting chlorine into my plumbing. It's hard on everything it comes into contact with.
There are a few majic filters on the Internet also. You might want to take them with a grain of salt.
speedbump is offline
Old 05-25-2010, 09:00 PM   #3
Thanks,
Rocky
No a Softner will not cure both problems, You have 2 different issues your dealing with. Your best answer is to get a treatment specialist to check your water and recommend the proper answer. I suspect your on a well system. Like Speedbump said Don't expect Majic cures on internet or Big Box stores to give you proper answers / results. We are in Frederick if you want to call.
QualityWaterLLC is offline
Old 12-27-2010, 10:45 PM   #4
Andy CWS's Avatar
Make sure your sulfur smell is actually coming from the well.
Take care of your water, and your water will take care of you.
Andy CWS is offline
Old 12-26-2012, 09:16 PM   #5
We have installed these non-chemical "magic filters" for over 30 years for low level sulfur and they work to perfection. You can buy them online from AffordableWater.us
BookemDannoDan is offline
Old 12-26-2012, 10:07 PM   #6
Liked 101 Times on 91 Posts
Likes Given: 19
Sorry Danno. A statement without proof is nothing in my book. Can you provide any laboratory testing proof?
johnjh2o Likes This
Old 12-27-2012, 12:48 PM   #7
Likes Given: 11
Resurrect a post from 2012 for that??? They're magic all rite!
softener, water softener
Water Softener Installation? prickett Water Heaters and Softeners 8 04-20-2012 02:46 PM
Water Softener Neglected veidtmeister Water Heaters and Softeners 3 11-28-2011 02:39 PM
Water Softener Problem? IanB Water Heaters and Softeners 3 09-23-2011 04:04 PM
Need a water softener Otahyoni Water Heaters and Softeners 20 04-12-2011 12:34 PM
Do I need to disinfect water softener? bendj Water Heaters and Softeners 3 05-11-2010 01:09 AM
