Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Water Heater Pipe Question
Old 07-21-2013, 08:43 AM   #1
magnum68
Likes Given: 2
Default Water Heater Pipe Question
Hi everyone, I'm new here and I am planning on having my water heater replaced. The top of my WH has the Hot & Cold water pipes and the high pressure relief valve. But at the bottom there is another pipe which I have no clue what it is. I don't plan on replacing this myself but would like to know what that extra line is for. Any and all help will be greatly appreciated.
Thanks
magnum68
magnum68 is offline
Old 07-21-2013, 01:21 PM   #2
Liked 189 Times on 137 Posts
Likes Given: 112
The extra pipe looks like a recirculation line for the hot water. It may be operating by gravity/convection, since there is no visible pump. When the tank is replaced, be sure to put a check valve on the recirc line unless one already exists under the insulation.
johnjh2o Likes This
Old 07-21-2013, 04:49 PM   #3
magnum68
Likes Given: 2
Thanks for the reply. What would happen if I don't have that extra pipe installed on my new water heater?
magnum68 is offline
Old 07-21-2013, 05:57 PM   #4
Liked 177 Times on 145 Posts
Likes Given: 123
If you have a heat pump with recovery heat there is a good chance the piping could be going to it. Check to see if you have 1/2'' piping outside at the heat pump or maybe a recovery box attach to the house by the heat pump.
Old 07-21-2013, 06:07 PM   #5
magnum68
Likes Given: 2
Hi, if there is a heat pump it's nowhere to be found unless it's behind the wall. I'm just curious if that line needs to be connected to the new water heater I plan to have installed. What I did for the moment was that I turned off that line using the water valve wheel and really saw no difference in water temperature or pressure. I just don't want that extra line connected to my new water heater if I really don't need it.
magnum68 is offline
Old 07-21-2013, 06:08 PM   #6
Likes Given: 123
The heat pump is the unit outside that helps heat & cools the house
johnjh2o Likes This
Old 07-21-2013, 06:12 PM   #7
Likes Given: 123
If the lines are connected to a heat pump recovery and the recovery is in uses then the lines should be reconnected.
Old 07-21-2013, 06:14 PM   #8
magnum68
Likes Given: 2
The only thing I have outside is the AC Compressor. I live in Florida, don't know if that makes a difference about the heat fan.
magnum68 is offline
Old 07-21-2013, 06:14 PM   #9
Likes Given: 218
IFIXH2O is correct that is from a heat recovery unit. At first glance I failed to see the other line on the top of the heater.
Old 07-21-2013, 06:22 PM   #10
magnum68
Likes Given: 2
I removed the insulation so you guys can have a better view of the line.
magnum68 is offline
Water heater feed pipe shot. and now i have to replace my whole heater. chucksrt Water Heaters and Softeners 1 05-20-2013 01:14 AM
Question on Hot Water Heater Recirc. Pump beantech Water Heaters and Softeners 2 08-13-2011 02:28 PM
Water heater failed, warranty question bmrowe Water Heaters and Softeners 3 05-09-2011 03:49 PM
50 gallon electric water heater question eaglesclaw121 Water Heaters and Softeners 5 12-29-2010 02:29 PM
Hot water heater question ConsiderThis General Plumbing Help 5 05-23-2010 04:27 PM
