Old 07-31-2010, 04:47 PM   #1
Default Water Harmonics- Loud Whine
My neighbor's house was built in 1955. Everytime the water is used, there is a loud whinning sound. The water company replaced the water meter( with a wireless reader and 5/8 inch), the pressure regulator was replaced and set to 50 psi and a bladder was installed on the water heater. We are running out of ideas and need your expertise and advice.
gordy49 is offline   Reply With Quote
Old 08-01-2010, 03:34 PM   #2
If you read some of the other posts about water harmonics, you will discover they can be hard to locate. One poster determined their noises was found in the check valves at the top of the water heater. Others discovered their toilet fill valves needed replacing.
To resolve this annoying problem, you will first need to do some detective work and attempt to follow the sounds and vibrations.
Good luck, and please let us know your outcome in order to help others with the same problem!
check valves, harmonics, noises, valves, water heater
