Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Water hammer caused by hot water tank
Old 09-24-2013, 02:45 AM   #1
DJ_Poop
Default Water hammer caused by hot water tank
I know this may sound strange but about 6 months ago we received a new washer to replace our old one under warranty as they could not fix it in time. The new washer turns the water on and off a lot faster and more frequently then the old front load. It was then I noticed the hammer was getting louder and louder, I followed the washer lines in the basement and secured them every 3 feet hoping this would help. It did not, after standing my the water meter where the noise is coming from I decided to shut off the cold inlet to the HWT and magically the hammer went away. Does anyone know a solution to this problem? Side note I have had a few issues with the back flow check valve in the dip tube of the HWT getting stuck and losing hot water sometimes or the pressure will drop off and then hear a clunk and the water pressure rises again.
Thanx in advance for any help
Richard
DJ_Poop is offline
Old 09-24-2013, 04:50 AM   #2
Haworthplumbing
Haworthplumbing's Avatar
You should have hammer arresters installed on both the hot and cold water lines to your washer. The hammer is caused from valves that open and close very quickly. The arresters will stop the water hammer.
Haworthplumbing is offline
Old 09-24-2013, 11:58 AM   #3
Likes Given: 218
The newer clothes washers turn the water on and off very fast causing you problem. As stated above you need hammer arrestors. These connect between the washer hose and the faucet and work very well.
Old 09-25-2013, 12:01 AM   #4
DJ_Poop
Sorry I forgot to mention, one of the first things I tried was to install a hammer arrester between the washer and the laundry shutoff. That did nothing to help solve the hammer issue, we also only use the washer on cold setting never hot. I ran a cycle with the cold valve off and just the hot open and the hammer is not nearly as bad, vice versa with the hot closed and the cold open its the same amount of bang. I just find it odd that turning the shut off to the cold water supply of the HWT seems to solve the hammer when the washer is adding water.
DJ_Poop is offline
Old 09-25-2013, 03:45 AM   #5
Liked 188 Times on 136 Posts
Likes Given: 112
It's sounding as if you have high house pressure. With no other water running in the house, you can test your water pressure at a hose connection with a gauge. Many home improvement stores and hardware stores have them.
The owners manual should have the recommended pressure listed somewhere in the book. This is also very important if you call for any warranty repairs, so let us know when you get the reading.
Old 10-02-2013, 02:23 AM   #6
DJ_Poop
Sorry it took me so long to get back to you, i was out of town with work. I bought a pressure gauge and it was reading 50psi with nothing else running in the house. Any more help with this would be greatly appreciated.
Thank you
DJ_Poop is offline
Old 10-03-2013, 02:57 AM   #7
Liked 176 Times on 144 Posts
Likes Given: 122
Do you have a pressure reducing valve , Is there a expanison tank at the water heater ? If your t&p valve keep opening then the valve spring is weak or you have other issues causing it to open.
Water Hammer Arresters mcintoshmc General Plumbing Help 10 03-22-2013 04:07 AM
Shower leak caused water to get between walls... lisah Showers and Tubs 2 05-17-2012 12:09 AM
Water hammer trouble Komodo General Plumbing Help 7 05-13-2011 12:54 AM
Water Hammer opsuv83 General Plumbing Help 4 02-20-2011 10:50 PM
Water Hammer DennisF General Plumbing Help 20 07-30-2010 05:53 PM
