Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Washer and Sink drain
Old 03-18-2012, 12:51 AM   #1
Default Washer and Sink drain
I am remodeling a house I bought for my mother. She lived there 6 months last year and decided to move back to her home. Now, I am remodeling the basement to get it sold. I cut out the galvanized plumbing and some of the cast iron drain pipe this weekend. The cast iron pipe served the kitchen drain and a Y from it served the washing machine. The two drains are directly in sight of each other on oppisite sides of the house. I would like to run 1-1//2 PVC from the kitchen drain to a 2" tee to pick up the washing machine, then a trap and over to the main line. Will the trap cause troubles and not do it's job?
dsell is offline
Old 03-18-2012, 01:40 AM   #2
Plumbero007's Avatar
any pictures?. it would help. Washing machine needs its own, separate trap. Where is the vent for all this?
Stan
remodel-my-bath.com
Serving ATLANTA and North West GA since 1992
http://remodel-my-bath.com
Plumbero007 is offline
Old 03-18-2012, 02:53 AM   #3
Ok, I took some pictures.
dsell is offline
Old 03-18-2012, 02:55 AM   #4
The green plug in the pictures is where the kitchen drain did go. The 4 inch cast iron pipe goes through the roof for the vent.
dsell is offline
Old 03-30-2012, 08:16 PM   #5
Administrator
Austin's Avatar
Liked 31 Times on 29 Posts
Likes Given: 116
Can anyone help out here?
Austin is offline
Old 03-31-2012, 01:11 PM   #6
Is a kitchen drain vented?. Check the roof above kitchen sink.
If you have window above kitchen sink there should be a vertical vent pipe on ether side of the window. If the sink is vented, run 1 11/2 or 2" if posible to 2" "Y". Remove old bucket trap from washing machine and instal new p-trap and connect to other side of the Y (as it is now). All this will work fine if kitchen drain line is conventionally vented. take a good pic of under the sink area in the basement, and post it here. take another shot inside kitchen cabinet so we can help you determine if kitchen sink is vented.
stan
Stan
remodel-my-bath.com
Old 04-01-2012, 01:58 PM   #7
The kitchen drain is not vented. Thanks for the reply.
dsell is offline
Adding three sink to washer drain vaportx Plumbing Building Code 13 01-19-2013 12:00 AM
Adding a washer drain to main drain stack.... phantomvs General Plumbing Help 10 07-22-2012 12:18 AM
Loud gurgling from sink/tub when washer empties. tireshark General Plumbing Help 3 04-24-2012 01:16 AM
New utility sink + washer drain line brownetowne Toilets and Sinks 0 06-26-2011 10:42 PM
How to add Utility Sink and Washer Drain to existing drain stack obriendigital General Plumbing Help 1 03-27-2011 02:15 AM
