Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > washer machine drain question
Old 01-04-2014, 01:44 AM   #1
matt9855
Default washer machine drain question
i am looking to add a washer machine to my basement, but connecting the drain to the horizontal run i don't have 18" from the top of the horizontal drain to to the top of a stand pipe. So I was wondering if i could tee in where the C/O is, put a C/O after the new tee and the I would have room for a trap and AAV for my washer drain. the standpipe that you see in the picture is for a water softner drain. Any suggestion would be appreciated
matt9855 is offline
Old 01-04-2014, 03:30 AM   #2
Liked 176 Times on 144 Posts
Likes Given: 122
Are you saying the washer will set lower than the main drain line ?
Old 01-04-2014, 10:20 AM   #3
matt9855
yes washer machine will be in hte basement
matt9855 is offline
Utility sink drain pipe attached to washer machine drain pipe pcanaveral Toilets and Sinks 1 12-28-2013 07:30 PM
Washing machine drain pipe question. . . . . tomassmid General Plumbing Help 4 11-27-2013 06:15 PM
Washer Machine Shutoff Valve ccg19072 General Plumbing Help 5 02-25-2012 11:00 PM
washing machine question topcop1000 General Plumbing Help 1 10-29-2011 01:57 PM
Tub and washer machine connected same drain ryan1340 General Plumbing Help 2 05-06-2011 09:58 PM
