Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Warped water heater?
Old 11-17-2012, 03:52 AM   #1
airmax617
Default Warped water heater?
It looks like the bottom of my water heater is warped. Is this dangerous? The model is Weil McLain Gold Plus 40. It also has a slight leak in the back, hence the water.
Thanks!
airmax617 is offline
Old 11-17-2012, 04:00 AM   #2
stevemachine
Liked 89 Times on 78 Posts
Likes Given: 91
How old is it? It's weird it warped like that, never saw that before. And where is the leak? From the boiler drain, t&p or the tank?
Old 11-17-2012, 04:34 AM   #3
airmax617
i am not sure, we just purchased the home. It was built in 1999. The leak is coming from the pipe from the bottom, which i guess is the drain.
Please see pictures for model number and where the leak is coming from.
Thank you so much for your help.
Old 11-17-2012, 04:37 AM   #4
airmax617
Default pictures
pictures, please see attached. did not come out in the previous post.
Old 11-17-2012, 04:43 AM   #5
stevemachine
Likes Given: 91
Ok since it's Weil McLean I'm guessing its a indirectly fired water heater. Do you have a separate boiler? The pipe on the bottom looks like its the supply to heat up the water heater for the indirect water heater. If that pipe is leaking you'll have to shut down and drain the boiler and replace the pipe and fittings where its leaking from. As to why its warped again I've never saw that before. If its not leaking that's good haha. I'm sure someone else can chime in and may have an answer for that.
Old 11-17-2012, 04:45 AM   #6
stevemachine
Likes Given: 91
Or if there's valves it'll need to be isolated to fix the leak. And you're welcome!
Old 11-17-2012, 04:47 AM   #7
stevemachine
Likes Given: 91
Actually took a second look and it may have warped due to the leak. The insulation probably got wet and and now the outer shell, must have been leaking for a while is my guess just maybe not noticeable till lately.
Old 11-17-2012, 04:48 AM   #8
airmax617
Thanks. Do you think this means I will need to get a new heater? i will have to get a plumber to come out to fix the leak, but can the water heater operate normally/safely if this has occurred?
Old 11-17-2012, 02:58 PM   #9
stevemachine
Likes Given: 91
I don't think it an issue unless it is leaking, however when the plumber is there get him to inspect the heater and make sure the heater itself isn't leaking. Obviously if the heater is leaking then yes replace it. Also avoid mr. Rooter, they charge a lot and usually there guys aren't all that qualified. Just do a bit of research and see who does good work in your area. Some of those companies who charge flat rates to do the work tend to be expensive, I used to work for one and our prices were outrageous.
Water in bottom of heater tank - and - hot water in cold lines SteveRiley Water Heaters and Softeners 14 11-09-2012 12:17 AM
Tankless Hot Water Heater, Noritz N0751M Will Not Heat Water iceundersiege Water Heaters and Softeners 6 04-03-2012 03:21 AM
Water heater connection to boiler domestic hot water coil gillric Water Heaters and Softeners 2 11-11-2011 11:16 AM
intermittent scalding water from electric water heater provlima Water Heaters and Softeners 2 02-21-2011 01:29 AM
problem..scalding water from electric water heater provlima Water Heaters and Softeners 2 12-14-2010 02:37 AM
